Calculation loss of energy due to friction?
The discussion revolves around a homework problem related to calculating energy loss due to friction. The user is struggling to derive the correct answer using the equation Wnet=change in KE and Wnc=Change in Energy. They attempted to apply the formula Fs(h*cos15) but found their results inconsistent with the expected answer. Clarification is sought on the meaning of F and s in the equation, as well as the derivation of the expression involving kinetic friction. The user also explains their use of the Pythagorean theorem to calculate the slope distance based on the given height.
okgo
http://i43.tinypic.com/i1bq1i.jpg
I need help with number 9
Wnet=change in KE
I haven't been able to get the answer marked by the computer.
I tried Fs(h*cos15)=.5mv^2-mgh
and that is way off the anwser
Can you explain that equation? I don't understand what F and s are, or how you derived Fs(h*cos15).
sorry I meant that F(k) which is the force due to kinetic friction.
The equation for work is FDcos(theta). They gave use the height so I calculated the distance of the slope by Pythagorean theorem which gives cos(15)*the height.
