Calculation of friction coefficient between wheel and road
To calculate the friction coefficient between a car tire and the road, the torque equation is essential, incorporating engine, braking, acceleration, inertial, drag, and rolling resistance torques. The inertial torque component can generally be neglected if massless wheels are assumed; otherwise, it must be included. The Coulomb friction model indicates that friction does not depend on slip, but the friction coefficient (Mue) does vary with slip when the vehicle is already slipping. Understanding this relationship is crucial for accurately determining braking force coefficients in dynamic conditions. The discussion emphasizes the complexity of modeling friction accurately in practical scenarios.
Raj
Hi all,
I need to calculate the friction coefficient between road and the tyre of the car.
I came across few answers like which solves as from the following torque equation.
Engine torque = braking torque + acceleration troque + Inertial torque + drag torque + rolling resistance.
For braking, Engine torque = 0. and the braking torque is assumed to be Cp * (Braking pressure).Acceleration torque is taken as (F = (Mue)* (Normal force i.e., the weight on the wheel)).
The inertial component is taken as J*(omega_dot). where omega_dot is the derivative of angular velocity of the wheel.
is the inertial torque component significant? can it be neglected?
How can the Mue of the road at slip = 0 be calculated as the Mue varies with the slip?
You can neglect the inertial term provided you use massless wheels for which J = 0; otherwise, no, it must be included.
You are asking too much of a simple model here. The Coulomb friction model, Ffriction <= mu * Fnormal, does not depend on slip. When you use the equals sign, you are saying that slip is (1) impending or (2) slip is occurring.
Thanks for the reply, I would like to know in the case where vehicle is already in slip. I read some where that the friction between the tire and road vary with the variation in slip. So, I am trying to calculate the variation of Mue(Braking force coefficient) with respect to slip. Please refer the following attachment to know about its variation.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
