What is the Length of a Parabolic Segment Using Calculus 3?
GreenPrint
Find the length of the parabolic segment r = \frac{12}{1+cos(θ))}, 0\leqθ\leq\frac{∏}{2}.
L = ∫\sqrt{f(θ)^{2}+f^{'}(θ)^{2}}dθ
I got up to here and didn't know whta to do
L = 12 ∫^{0}_{\frac{∏}{2}} \frac{1}{1+cos(θ)}\sqrt{1+(\frac{sin(θ)}{1+cos(θ)})^{2}}dθ
Wolfram alpha doesn't know neither
f(θ)^{2} = (\frac{12}{1+cos(θ))})^{2}
f^{'}(θ)^{2} = (\frac{12sin(θ)}{(1+cos(θ))^{2}})^{2}
\sqrt{f(θ)^{2}+f^{'}(θ)^{2}} = \sqrt{(\frac{12}{1+cos(θ))})^{2}+(\frac{12sin(θ)}{(1+cos(θ))^{2}})^{2}}=\frac{12}{1+cos(θ)}\sqrt{1+(\frac{sin(θ)}{1+cos(θ)})^{2}}
Mod note: Fixed incorrect = in the identity below.[/color]
First, simplify the integrand using trig identities such as \sin^2(\theta) + \cos^2(\theta) = 1. After that, Maple manages to do the integral, but I won't report the answer here: you can try again after simplification, substitution, etc. BTW: to get \int_{0}^{\pi/2} you need to type \int_{0}^{\pi/2}, not what you typed.
RGV
oh hm ok thanks i got to go ill be back later
well i tired to simplify it further but keep on getting stuck
12 square root (2) * integral[0,pi/2] d theta/(sin(theta)+sin(2*theta))
is as far as i got
I entered a approximation into the answer box and it told me i was wrong so i guess it wants a exact answer
here is what it said (see attachment) I'm not sure it really helps
also note that I tried to evaluate
using trig substitution with angle alpha
cot(alpha)^2/2 = cos(theta)
I would have to solve for theta
and then find d theta/ d alpha
solve for d alpha
and use the fact that
cos(alpha)^2/sin(theta) = 1/(sin(theta)+sin(2theta))
but I'm not sure if this will all work
i believe that it's equivalent
that is 12 square root (2) * integral[0,pi/2] d theta/(sin(theta)+sin(2*theta))
So here is were I'm at now
L = 12 ∫^{\frac{∏}{2}}_{0} \frac{1}{1+cos(θ)}\sqrt{1+(\frac{sin(θ)}{1+cos(θ)})^{2}}dθ
from here I used the fact that
1 + cos(θ) = 2cos^{2}(\frac{θ}{2})
so
\frac{sec^{2}(\frac{θ}{2})}{2} = \frac{1}{1+cos(θ)}
similarly
\sqrt{1+(\frac{sin(θ)}{1+cos(θ)})^{2}} = \sqrt{1+\frac{sec^{4}(\frac{θ}{2})sin^{2}(θ)}{4}}
So I know have the following
L = 12 ∫^{\frac{∏}{2}}_{0} \frac{1}{1+cos(θ)}\sqrt{1+(\frac{sin(θ)}{1+cos(θ)})^{2}}dθ = 12 ∫^{\frac{∏}{2}}_{0} \frac{sec^{2}(\frac{θ}{2})}{2} \sqrt{1+\frac{sec^{4}(\frac{θ}{2})sin^{2}(θ)}{4}}dθ
from here I use the fact that
sin^{2}(θ)=4sin^{2}(\frac{θ}{2})cos^{2}(\frac{θ}{2})
wolfram alpha confirm it's true
http://www.wolframalpha.com/input/?i=sin(x)^2=4sin(x/2)^2*cos(x/2)^2
plugging this in I get
12 ∫^{\frac{∏}{2}}_{0} \frac{sec^{2}(\frac{θ}{2})}{2} \sqrt{1+sec^{4}(\frac{θ}{2})sin^{2}(\frac{θ}{2})cos^{2}(\frac{θ}{2})}dθ=6 ∫^{\frac{∏}{2}}_{0} sec^{2}(\frac{θ}{2})\sqrt{1+sec^{2}(\frac{θ}{2})sin^{2}(\frac{θ}{2})}dθ, u = \frac{θ}{2}, \frac{du}{dθ}=\frac{1}{2},du=\frac{dθ}{2},dθ=2du,L=12 ∫^{θ=\frac{∏}{2}}_{θ=0} sec^{2}(u)\sqrt{1+sec^{2}(u)sin^{2}(u)}du=12 ∫^{θ=\frac{∏}{2}}_{θ=0} sec^{2}(u)\sqrt{1+tan^{2}(u)}du
then from here I use
sin^{2}(θ))+cos^{2}(θ)=1
that if I divide through by cos^{2}(θ) I get
tan^{2}(θ))+1=sec^{2}(θ)
L=12 ∫^{θ=\frac{∏}{2}}_{θ=0} sec^{2}(u)\sqrt{sec^{2}(u)}du=12∫^{θ=\frac{∏}{2}}_{θ=0} sec^{3}(u)du
then because
∫sec^{n}(x)dx = \frac{sec^{n-2}(x)tan(x)}{n-1}+\frac{n-2}{n-1}∫sec^{n-2}(x)dx
we got
12∫^{θ=\frac{∏}{2}}_{θ=0} sec^{3}(u)du=12[\frac{sec(u)tan(u)}{2}+\frac{1}{2}∫sec(u)du]|^{θ=\frac{∏}{2}}_{θ=0}
and because
∫sec(x)dx=ln|sec(x)+tan(x)|+c
we got
12[\frac{sec(u)tan(u)}{2}+\frac{1}{2}∫sec(u)du]|^{θ=\frac{∏}{2}}_{θ=0}=12[\frac{sec(u)tan(u)}{2}+\frac{1}{2}ln(|sec(u)+tan(u)|)]|^{θ=\frac{∏}{2}}_{θ=0}
plugging back in
u = \frac{θ}{2}
we got
12[\frac{sec(u)tan(u)}{2}+\frac{1}{2}ln(|sec(u)+tan(u)|)]|^{θ=\frac{∏}{2}}_{θ=0}=12[\frac{sec(\frac{θ}{2})tan(\frac{θ}{2})+ln|sec(θ/2)+tan(\frac{θ}{2})|}{2}]|^{θ=\frac{∏}{2}}_{θ=0}=12[\frac{sec(\frac{∏}{4})tan(\frac{∏}{4})+ln(|sec(∏/4)+tan(\frac{∏}{4})|)}{2}-\frac{sec(0)tan(0)+ln(|sec(0)+tan(0)|}{2})=12[\frac{\sqrt{2}+ln(|\sqrt{2}+1|)}{2}-0]=6(\sqrt{2}+ln(\sqrt{2}+1))
I haven't worked the problem through, but here is what I got.
r2 + (r')2 = \frac{288}{(1 + cosθ)^3}
You still need to take the square root, and then integrate that result. No doubt another trig identity will come in useful.
I have no idea how you got that. I get
\frac{144}{(1+cos(θ))^{2}} + \frac{144(1-cos^{2}(θ))}{(1+cos(θ))^{4}} = \frac{144}{(1+cos(θ))^{2}}(1+\frac{1-cos^{2}(θ)}{(1+cos(θ))^{2}})
when I try to expand it
well i found one mistake in my work i forgot to square the two let's see...
In the first line above, 1 - cos2θ = sin2θ, right?
yes...
if you see I believe I had the right answer above... I actually got an answer which is a improvement...
I got the integral of sec^3(x) dx
but I get the wrong answer did I use the wrong reduction formula or something =( I think it's the right reduction formula but I'm not sure
ok well i did use the right reduction formula
at first i had tan(pi/4)=sqrt(2)/2 but it's one i fixed that and updated my answer above
I don't see what I've done wrong but apparently it is
my calculator gives me 13.77735
and when i put in the answer i got i get 7.4787
I checked what I had in wolframalpha, and got 13.7735 (two 7's, not 3), which sort of agrees with your calculator answer.
You have a ton of stuff in post #6, too much to wade through to find an error.
The integral should look like this, if my work is correct:
12\sqrt{2}\int_0^{\pi/2} \frac{d\theta}{(1 + cos\theta)^{3/2}}
There's a half-angle identity that might be useful here: cosθ + 1 = 2 cos2(θ/2). This turns the integral above into
12\sqrt{2}\int_0^{\pi/2} \frac{d\theta}{(2^{3/2}cos^3(\theta/2))}
Then it should be a relatively simple matter of integrating sec3 of something. There's a wikepedia page on this integral.
ya the only problem is that i don't think there is an error in my work i have checked over it a lot, it's not as long as it seems it's just that I showed each step and my reasoning and any formulas I used, I included the reduction formula for integrating secant
I got it down to
12 integral sec^3(u) du
similar to what you got
6*sqrt(2) integral sec^3(x)
interesting enough when i enter this into my calculator with limits i get divide by zero error :O when i try to put in what you got 12*sqrt(2)*integral[0,pi/2] sec^3(x)dx
and wolfram alpha
http://www.wolframalpha.com/input/?...t(2)*integral[0,pi/2]+sec^3(x)dx&incTime=true
couldn't give an approximation or exact answer
hmm...
it told me that the correct answer is
6*(sqrt(2)+ln(1+sqrt(2))
yay i got it right and found my error yippeeee
