Archived Calculus for delta function based on wave function
The discussion revolves around calculating the integrals <ψ|δ(r12)|ψ> and <ψ|δ(r1)|ψ> for a two-electron wavefunction defined as ψ(r1, r2, r12) = exp(-Ar1 - Br2 - Cr12). The user attempts to compute these integrals but seeks clarification on potential errors in their approach. A key point highlighted is the proper substitution of variables, specifically that r12 = |r1 - r2| simplifies to r2 when r1 is set to zero. Overall, the calculations are deemed correct, and the focus is on evaluating the integrals accurately.
sandf
Two-electron Wavefunction: ψ(r1,r2,r12) = exp(-Ar1-Br2-Cr12), r12 = |r1-r2|
A, B, and C are coefficients
Calculate <ψ|δ(r12)|ψ> and <ψ|δ(r1)|ψ>
NO
<ψ|δ(r12)|ψ>
= ∫∫dv1dv2ψ2(r1,r2,r12)δ(r12)
=4π∫dr2ψ2(r2,r2,0)
<ψ|δ(r1)|ψ>
= ∫∫dv1dv2ψ2(r1,r2,r12)δ(r1)
=4π∫dr2ψ2(0,r2,-r2)
Could you tell me where I am wrong?
Best regards.
sandf
NO
<ψ|δ(r12)|ψ>
=4π∫dr2ψ2(r2,r2,0)
<ψ|δ(r1)|ψ>
=4π∫dr2ψ2(0,r2,-r2)
Best regards.
sandf
To be precise, in the last step, one should use that ##r_{12} = |r_1-r_2|= r_2 ## upon setting ##r_1=0##. But other than that, everything is good, one simply has to calculate the integrals which are easy.
