Calculus N00b: Find the Second Derivative
  • Thread starter Thread starter gschjetne
    Calculus Stuck
The discussion focuses on finding the second derivative of the function f(x) = (2-3x)/x^2. The initial attempts at calculating the derivatives were incorrect, prompting suggestions to use the power rule and decompose the function into simpler terms. After applying the correct methods, the second derivative was found to be f''(x) = (12-6x)/x^4, which matches the textbook answer. The user expressed a lack of understanding of the quotient rule and plans to seek additional help from a teacher. The conversation emphasizes the importance of correctly applying calculus rules to derive accurate results.
gschjetne
One of my biggest griefs is the fact that I'm a complete n00b when it comes to maths.
I'm supposed to find the second derivate of
f(x) = \frac{2-3x}{x^2}
I started out with this:
f'(x) = \frac{-3}{x^2} + \frac{2-3x}{2x}
f''(x) = \frac{3}{2x} + \frac{2-3x}{2}
But it didn't take long until I found I was just making gibberish... :frown:
Any ideas?
Nope.Both are incorrect.U should apply the rules properly.It's easier,if u decompose.
f(x)=2x^{-2}-3x^{-1}
Can u compute the derivatives now...?
Daniel.
P.S.HINT:Just the power rule involved.
Are you familiar with the quotient rule?
Thanks.
This should be correct, then:
f'(x)=-4x^{-3}+3x^{-2}
f''(x)=12x^{-4}-6x^{-3}
The textbook says it's \frac{12-6X}{X^4}, which, according to my graphing calculator identical to what I got above, but unfortunately both me and my father are lacking in skill to figure that out.
I have heard about the quotient rule, but I haven't been able to fully understand it. I'm going to ask my teacher for a tutor lesson tomorrow.
Hmm
\frac{12-6x}{x^{4}}=\frac{12}{x^{4}}-\frac{6x}{x^{4}}=12x^{-4}-6x^{-3}
Okay?
Daniel.
If you divide your final answer for f'' by x^4 you will find it gives the textbook answer ^_^
