Can a Bowling Ball Really Travel 200 Meters After Launching from a Ramp?
  • Thread starter Thread starter kurgen88
    Angle Impossible
The discussion revolves around calculating the launch angle of a bowling ball that rolls down a 12-meter hill and travels 200 meters after leaving a ramp at a speed of 13.09 m/s. The poster expresses skepticism about the feasibility of the ball traveling such a distance, questioning if it’s a trick problem. Various equations related to projectile motion are mentioned, including the range equation and the relationship between angle and distance. Suggestions include using algebra to isolate the angle from the sine function and noting that the calculated angle will need to be halved to find the actual launch angle. The feasibility of achieving the stated distance is a key concern in the calculations.
kurgen88
A solid bowling ball rolls down a hill with a height of 12.00 meters. The end of the hill has a ramp/jump which has an unknown angle above the horizontal. When the ball leaves the ramp at the unkown angle, its speed is13.09 meters per second and travels a distance of 200.0 meters.
I need to solve for the angle which the ball leaves the ramp, but the fact that the ball travels 200.0 meters seems like it is impossible. Is this a trick question? Does anyone have any suggestions on how I can solve for this?
gravity*distance=-2V^2 * sin(theta)cos(theta)
or...
-Sin(2theta) = (gravity/initial velocity^2)
...where gravity = 10.0 meters/sec^2
I have tried to solve this way but I don't think I can isolate theta from Sin(2
Look in your handbook at the section on projectile motion. Try and find the range equation of a projectile. The range of a projectile is the horizontal distance it travels from the launching point up to the point where it hits the ground.
I am at the point given in the equation below. Is it possible to solve for theta here? Can you use algebra to extract theta form sin(2*theta) ? What happens to sin(2 ?
If you take the inverse sine of the calculated value (arcsin) you will get an angle. This angle is then twice the angle you want (2\theta _o).
Note that in your equation above you omitted R.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
