Can a Laser and Reflective Material Create a High-Frequency Microphone?
  • Thread starter Thread starter Raven Luni
    Acoustic Design
A discussion on creating a high-frequency microphone using a laser and reflective material explores the potential of detecting frequencies up to 100 kHz. The idea involves bouncing a laser off reflective material, with methods including phase shift detection through pulse width modulation and Doppler shift analysis. Key considerations include the choice of material properties such as thickness, surface area, and tension, as well as the possibility of a resonant frequency. Participants share resources, including patents and examples of existing acoustic sensors and optical detectors. The feasibility of this approach for the desired frequency range remains a central question.
Raven Luni
Greetings,
I've been looking for a way to create a microphone capable of picking up high frequencies (up to about 100kHz). Electrets don't tend to go that high and piezo crystals even detuned will only give a limited band.
I had the idea of bouncing a laser off a sheet of reflective material. The light can either be picked up directly, by pulsing the beam with a square wave and taking the phase shift as a form of pulse width modulation, or with a sine wave and using the doppler shift (I'll have fun experimenting with all these methods).
What I don't have any clue about is the material and what properties it should have. What kind of thickness, surface area, tension etc. would I need? Would there be a resonant frequency? Is it even possible for the frequency range in question?
Raven Luni, Welcome to Physics Forums! 
You may see this patent, which detects acoustic frequencies up to 100 kHz:
http://www.google.com/patents/US5146083
Here is a ready-made acoustic sensor you may learn from:
http://www.digikey.com/us/en/techzone/sensors/resources/articles/ultrasonic-mems-sensor-spm0404ud5.html
Excellent information - thanks :)
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
