Can an electric arc cause a combustion or fire if
An electric arc can indeed ignite a 91 percent alcohol solution if it is sprayed in the vicinity of the arc. Alcohol is highly combustible in air and can be easily ignited by sparks, which are common ignition sources. The presence of an electric arc increases the risk of combustion due to the high temperatures and energy involved.
Chemistry news on Phys.org
Alcohol is combustible in air. It is easily ignited. Sparks are ignition sources.
Likes strk
Thank you sir! this solves my questions. thanks for the help.
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
