Can anyone confirm this equation? Prop. Thrust
  • Thread starter Thread starter nickpark83
    Thrust
The discussion centers on the confusion surrounding the calculation of propeller thrust, highlighting discrepancies between results obtained from a NASA-derived formula and various online calculators. The proposed thrust equation involves parameters like density, propeller radius, RPM, and an efficiency coefficient, yet users report significant variations in outcomes. A secondary equation is also suggested, relating thrust to engine power, density, and propeller area. Participants seek clarification on which formula yields accurate results for propeller thrust. The conversation underscores the need for reliable formulas and consistent calculations in propeller thrust assessments.
nickpark83
can anyone confirm this equation?? Prop. Thrust
there are many websites that calculate propeller Thrust, and they never show any formulas for it... and i somehow manage to find the formula from NASA website, but when i compare the result with each other, i get totally different numbers...
Thrust = (density)(pi)(radius of prop)^2(2)[(2Vk(RPM) + k(RPM^2)]
where k is coefficient of efficiency of prop.
V = speed, V=0 when static
if i just work with the units only, i get the force unit no problem, but the result is way off from the number from websites..
anyone know which one is correct?
You might want to try this one:
T=P_{io}^{2/3}(2 \rho A)^{1/3} where
T = thrust
P_{io} = (induced) power of the engine
\rho = density
A = propeller area
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
