Can anyone tell what's wrong with my circuit?
  • Thread starter Thread starter UWouldKnow
    Circuit
The discussion centers on troubleshooting a malfunctioning Arduino circuit where a relay is not activating LEDs as intended. Participants emphasize the importance of sharing circuit diagrams and code to diagnose issues effectively. Key suggestions include checking power connections, verifying code execution, and using a multimeter for basic checks. A critical error identified is a reversed flyback diode in the breadboard layout, which prevents the relay from operating. Properly addressing this diode issue is essential for the circuit to function correctly.
UWouldKnow
I am doing basic tutorials with an arduino but I can't seem to get this circuit to work. I hooked everything up and ran the given code but nothing happens. The relay is supposed to trigger the led's on and off but when I run the code the relay isn't even making any noise
most of your images are missing
show us your circuit diagram(s) for the circuit
also show the code for the micro
Likes UWouldKnow and Asymptotic
Have you tried running everything off battery power (or wall wart) instead of USB? Without seeing a schematic or relay number that would be my guess.
Likes UWouldKnow
It concerns me that so many circuit experimenters seem to present their questions in the form of pictures of a breadboard layout. Am I so old fashioned in expecting a symbolic circuit diagram? I wouldn't expect someone with an arithmetic problem to have it presented in terms of piles of beans. I wonder if it's the general habit to work with wires and components, directly form the device spec sheet. A breadboard realisation of fast circuitry - or even slow analogue - can be full of parasitics.
Likes davenn, gleem, cnh1995 and 1 other person
Have you got a multi-meter and done some basic checks? eg is power getting to all the places it should? Is there any evidence the code is running? eg is the pin that drives the relay changing? That check alone might narrow the problem down to one half of the circuit or the other.
Likes UWouldKnow
I notice the OP has not replied to any of this. Perhaps he needs a chance to do some checking of his wiring and code.
We tend to forget how hard troubleshooting can be to the uninitiated (and even the initiated).
Likes CWatters and davenn
Thanks, I'll try that... I think that's what the issue is. What do you mean by wall wart? Is that something that converts the wall power into something suitible for an arduino
Sorry I didn't mean to bother, I was just wondering if someone could see any obvious issues right off the bat. I was just curious as I am trying to learn and am in no need to try to get this circuit to work. The circuit diagram and code was made by a starter kit, so I am assuming that their circuit and code is correct. I should have been more clear and explained that
Interesting, I would be glad to run some test with my multimeter but I have no idea what to check for. And you it receives the code but it is just not doing anything.
The code and circuit diagram was created by a starter kit so I was assuming that it is correct, I could still add them to the chat if your interested though.
we ALL want to see them so that we have a better understanding of what you are talking about
again ... please post them
Okay I just posted them
Troubleshooting:
The purpose of the following is not to make you feel bad - it's exactly what I (and the others here) would be checking from the very start)
Take nothing for granted about what you have done. Assembling circuits is an alien world for most people.
First of all, do you have your supply volts and ground actually arriving at your breadboard (both places) and processor?
Does the processor actually give you a different voltage on Pin 2 when it's supposed to? That test will determine if your code is ok. If that's a fail then look again at your code.
Are all the leads firmly in contact with the holes on the board?
Does the collector volts go 'down' when Pin 2 volts go 'up'?
I forgot - the most important is to check (twice) that the connections really are on the correct pins and not on a 'mirror image' in your head when you are looking at the thing upside down? (Happens every day!)
Is the transistor emitter actually connected to ground?
etc etc.
This is not a whole afternoon's work but something that need only take a couple of minutes and would be 'automatic'.
With luck, you may find one of the above tests 'fails' and you will have found your circuit fault.
Likes cnh1995
Are either of the LEDs lit?
If +5V and 0V (ground) are connected to the circuit then the LED on the N.C. relay pole ought to be on.
To isolate the transistor and Arduino output pin 2 from contention, temporarily disconnect the transistor collector wire, and jump it to ground. The relay coil should energize, switch the contacts, and the other LED ought to turn on.
If the relay doesn't switch, then a problem exists in this 'half' of the circuit.
If the relay operates, and the other LED turns on, then the problem is on the Arduino/transistor side.
Likes davenn, cnh1995 and sophiecentaur
You'll most likely be able to resolve the problem using the troubleshooting tips from Sophiecentaur and asymptotic.
My two cents: I believe it is also possible that your arduino board is sourcing too much current (coils+LEDs). That gives you an error message "problem uploading to board" when you try to run the code. What is the current rating of the relay coil? Try using a separate 5V supply to feed the coil.
Edit: I don't see a mention of such error message in your OP. Are you sure the code was uploaded successfully?
Likes Asymptotic
This is a great idea, and has shaken loose another possibility ... is the Arduino USB cable plugged directly into a computer USB port, or is it plugged into a USB hub? An unpowered USB hub doesn't have much current sourcing capacity, and more often than not, doesn't have the juice to power an external HDD.
Likes rbelli1 and cnh1995
Is the diode the wrong way around?
EDIT: Scratch that - the diode IS the wrong way around, even in the breadboard diagram. Not your fault. The circuit diagram is correct. Give the person who drew the breadboard diagram an insulting slap across the face.
Likes Asymptotic, sophiecentaur, davenn and 2 others
yup, good spotting
the flyback diode is reversed on the breadboard layout :smile:
result ... the relay won't operate
As @sophiecentaur said earlier, this is why we wanted the diagrams etc so we could check for errors
NOTE ... DONT DO Asymptotic's test UNTIL you have reversed the diode and checked operation, else you will just be shorting the 5V to ground via the poor diode and it probably won't survive that
Dave
Likes Asymptotic and phinds
