Can Digital Signals Be Transmitted Over FM for FSK Modulation?
Digital signals can be transmitted over FM for Frequency Shift Keying (FSK) modulation, but they do not have infinite bandwidth; they are real signals with finite bandwidth. When using FSK, the carrier is modulated with two frequencies, and the transition between these frequencies must be optimized to comply with RF spectrum regulations and avoid FCC violations. The discussion highlights the importance of understanding the finite nature of digital signals and their slew rates in practical applications. Calculating the optimum transition waveshape is crucial for effective transmission, especially at low bit rates. Overall, the conversation emphasizes the need to apply real-world considerations to digital signal transmission over FM.
engcon
Hi,
I'm thinking about transmitting digital signals with FM. The effect I'm trying to achieve is FSK.
Can I just feed the digital signal to the input of the FM transmitter?
With FSK the carrier is frequency modulated with 2 frequencies, but since the digital signal has infinite bandwidth, will the resulting frequency modulated carrier have just 2 frequencies?
Thanks
engcon said:
Hi,
Thanks
The digital signal is a real signal, so it does not have infinite BW. Furthermore, for optimum use of the RF spectrum (and to help you avoid violating FCC rules with your transmissions), there is an optimum slew rate and shape between the two different frequencies in BFSK. Can you tell us a bit about how you can determine this optimum transition waveshape?
Thanks for your reply. I must first say that I'm fairly new to this kind of stuff.
If you had to decompose the digital signal into sine waves using the Fourier Series, wouldn't that require an infinite number of sine waves for perfect replication?
Regarding the optimum slew rate, I have no idea how to calculate that. However, the maximum bps to be transmitted is very low (less than 100).
Don't confuse the ideal/surreal world of infinitely sharp digital signal representations with the real world, where digital signals have finite slew rates and finite bandwidths. You're asking about FM in the real world (I think), so the digital data stream will have a finite bandwidth.
And for the optimum wave-shaped digital modulating signal characteristic, check out MFSK here:
http://en.wikipedia.org/wiki/Frequency-shift_keying
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
