Can I Add Sine and Cosine Functions with a Non-Factorable Scalar?
  • Thread starter Thread starter mutzy188
    Cosine Functions
To add sine and cosine functions with non-factorable scalars, expand the cosine term using the angle addition formula. For example, in the expression 5*cos(wt) + 6*cos(wt + π/4), first expand cos(wt + π/4) into its components. After expansion, group like terms to simplify the expression. The result can be expressed in the form R*cos(wt ± A) or R*sin(wt ± A). This method allows for the combination of the functions despite the presence of scalars.
mutzy188
Hi guys,
I don't know if this should go here because it is an excerpt from a higher level problem. The part where I get stuck is when I try to add the cosine functions.
Is there any way to add sine and cosine functions that have a scalar in front that cannot be factored out? For example:
5*cos(wt) + 6*cos(wt + pi/4)
If there weren't any numbers in front of the functions then I could use the trig identity. What can I do with the numbers there? Thanks
5cos(wt) + 6*cos(wt + π/4)
expand out cos(wt+π/4) then group the like terms. Then you can either put in the form Rcos(wt±A) or Rsin(wt±A)
cos(A+ B)= cops(A)cos(B)- sin(A)sin(B).
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
