Can internal energy be calculated from equation of state?
The discussion centers on calculating internal energy using the equation of state, specifically through the relationship \(dU=TdS-PdV\). The user explores expressing entropy \(S\) as a function of pressure \(P\), volume \(V\), or temperature \(T\) using Maxwell's relations. It is established that while terms can be derived from the equation of state, the term \(\left(\frac{\partial V}{\partial T}\right)_S\) requires additional information, specifically the heat capacity, to complete the calculation. The consensus is that both the equation of state and heat capacity are essential for accurate internal energy calculations.
  • Understanding of thermodynamic principles, specifically internal energy and entropy.
  • Familiarity with Maxwell's relations in thermodynamics.
  • Knowledge of equations of state for various substances.
  • Basic concepts of heat capacity and its role in thermodynamic calculations.
  • Study the derivation and application of Maxwell's relations in thermodynamics.
  • Research specific equations of state for different materials, such as the Van der Waals equation.
  • Learn about heat capacity and its significance in thermodynamic processes.
  • Explore advanced thermodynamic calculations involving internal energy and entropy changes.
Students and professionals in thermodynamics, physicists, and engineers involved in energy calculations and material properties analysis.
arpon
We know,
$$dU=TdS-PdV$$
##\int PdV## can be calculated if the equation of state is given.
I tried to express ##S## as a function of ##P ,V## or ##T## (any two of those).
$$dS=\left(\frac{\partial S}{\partial V}\right)_T dV+\left(\frac{\partial S}{\partial T}\right)_V dT$$
$$=\left(\frac{\partial P}{\partial T}\right)_V dV+\left(\frac{\partial S}{\partial P}\right)_V \left(\frac{\partial P}{\partial T}\right)_V dT~~~ [Using ~~Maxwell's~~ relation]$$
$$=\left(\frac{\partial P}{\partial T}\right)_V dV-\left(\frac{\partial V}{\partial T}\right)_S \left(\frac{\partial P}{\partial T}\right)_V dT~~~[Using ~~Maxwell's~ ~relation]$$
All the terms except ##\left(\frac{\partial V}{\partial T}\right)_S## can be calculated using the equation of state.
Any suggestion will be appreciated.
Science news on Phys.org
You can't do it solely in terms of the equation of state. You need to use the heat capacity as well.
Thanks. That's exactly what I wanted to know.
  • · Replies 23 ·
  • · Replies 23 ·
  • · Replies 19 ·
