Can one move from Inertial to Magnetic Confinement?
Transitioning from inertial confinement fusion (ICF) to magnetic confinement fusion (MCF) is feasible, especially for someone with a solid background in plasma physics. While both fields are distinct, with significant differences in their underlying physics—such as the role of magnetic fields and plasma parameters—individuals can successfully switch between them. A strong focus on magnetic fusion during graduate studies is advisable for a career in that area, while those interested in ICF should concentrate on its specific dynamics. The discussion highlights the importance of understanding the plasma state, particularly in ICF, where the plasma parameter is notably low. Overall, pursuing research aligned with one’s career goals in fusion is crucial for success.
clope023
Hello all, my question is related to graduate school topics and future postdoc possiblities.
I'm a double major in electrical engineering and physics and have been doing plasma physics research as an undergraduate for roughly the last two years, with the last summer I played a part in installing a diagnostic onto the MAST tokamak at the Culham Centre for Fusion Energy. My current advisor says it's not necessarily a good thing to marry yourself to the research you did in undergrad, but I'm very much interested in doing fusion plasma research in graduate school and as a career. Though the option to stay and continue my research that I'm doing now at my ugrad institution is open, I'm very much interested in going elsewhere for graduate school. Assuming I got into a grad school that focused on inertial as opposed to magnetic confinement fusion. My question would be how feasible is it to move from inertial/laser confinement to a magnetic/tokamak sort of focus from grad school to post doc (assuming I went to my reach school in question)? I'm interested in diagnostics, plasma instabilities, as well as plasma-material interactions if that plays a part in your advice. Thanks for any and all opinions on the matter.
I don't think it would be much of a problem, especially since you are already focused on the plasma aspect.If all you worked on was laser physics and didn't know anything about plasmas that might be a problem, but sounds like that is not the case :)
People can and do make the switch, but If you want a career in magnetic fusion, study magnetic fusion. If you want a career in inertial fusion study inertial fusion.
The two fields are really very different. A critical aspect of magnetic fusion is the magnetic field. The shape and quality of the magnetic field influences everything from stability, to transport, to even the plasma-material interface. In inertial confinement fusion, the magnetic field is tiny compared the dynamical pressure. As a result most ICF research ignores any and all dynamics related to the magnetic field.
Similarly shock dynamics are a critical aspect of inertial confinement. Yet they play little role in conventional magnetic fusion confinement concepts.
As a final comment on the difference between the two. A critical parameter in plasma physics is the plasma parameter, which is the number of particles in a Debye Sphere. In order for something to be considered a plasma you need a large plasma parameter, and thus a lot of particles in a Debye Sphere. At IFC conditions relevant to ignition, the number of particles in a Debye Sphere is less than one, thus the plasma parameter is small. So in ICF at ignition, you don't actually have a classical plasma. The technical name for this new state is "strongly-coupled plasma," but this is misleading, and you arguably have a totally different state of matter.
The low plasma parameter is due to the small debye length for ICF?
Yes. The Debye length scales as n^{-1/2} and the plasma parameter scales as n\lambda_D^3 which also scales as n^{-1/2}. Both Debye length and the plasma parameter are small in ICF due to the large number densities.
Likes 1 person
Hello, I'm currently trying to compare theoretical results with an MCNP simulation. I'm using two discrete sets of data, intensity (probability) and linear attenuation coefficient, both functions of energy, to produce an attenuated energy spectrum after x-rays have passed through a thin layer of lead. I've been running through the calculations and I'm getting a higher average attenuated energy (~74 keV) than initial average energy (~33 keV). My guess is I'm doing something wrong somewhere...
