Can Power Line Communication Transmit Data Without Interrupting Power Supply?
Power Line Communication (PLC) can transmit data without interrupting the power supply, but it typically operates in a half-duplex mode, meaning data transmission may impact power delivery. The effectiveness of data transmission depends on the frequency used, as RF signals can propagate well along transmission lines, though transformers can hinder this process. To communicate effectively without interference from neighbors, techniques like OFDM or CDMA can be employed, but regulations must be checked for allowed communication bands. Modulation techniques such as FSK may be more suitable than ASK for transmitting data over 230V 50Hz signals. Overall, careful consideration of modulation methods and regulatory compliance is essential for successful PLC implementation.
yasthicklee
Hello,
I am new to this environment and I am about to do my final year project with the Power Line Communication.I am having some doubts regarding.Could anyone here explain how the data from my home can be transmitted to the energy station?
some says that the system comes with half-duplex.So if i am sending data,will i be having a power cut?
And if i am sending data with a low power,will that be reaching the energy station or will go to other homes in my neighborhood or even comes back to me??
some one explain
It depends on what frequency you intend to use but RF signals will propagate quite well along transmission lines. Transformers may be a bit of a barrier, though, and you may need repeaters (/ regenerators / high voltage bandpass filters) to get past them. As far as your neighbours are concerned, the problem is the same as for regular telephone lines; they may get some of your signals and, if you all want to communicate, you will need to use different frequency or time slots in a multiplex.
thx for the reply friend.In order to differentiate I planned to have either OFDM or CDMA technique in them.Is that feasible to make a Practical Home made CDMA or OFDA kit.
And how can I make a ASK in the 230V 50Hz signal as in my country?
You need to look up the government regulations for the different communication bands allowed on the powerline segments. There will be one set of rules for in the home, and another set of rules for the higher voltage supply lines and distribution transformers. And as mentioned, powerline comms do not usually make it through distribution transformers. Different comms are used on the two sides of distribution transformers.
It seems that Instead of making the modulation in the ASK I found its a bit good in the FSK format.I had a look at the Telephone system making the transfers in dc,LF,HF and in high freq.So I decided to do my project in FSK modulation.
Can I send the digitally modulated signals through the Live wires or should I have to convert that to analog to get that done?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
