Can power supplies cause temperature fluctuations....
Power supplies can indeed cause temperature fluctuations in a circuit, and they can also be sensitive to environmental temperature changes that affect circuit performance. The extent of these fluctuations depends on specific circuit components, such as zener diodes, resistors, and capacitors, which all respond differently to temperature variations. Voltage regulation issues are more likely to manifest as voltage changes rather than affecting current draw. Additionally, the proximity of heat-generating components to sensitive circuit elements can influence temperature effects. More detailed information about the specific circuit is necessary for a comprehensive analysis.
lcr2139
can power supplies cause temperature fluctuations in a circuit? Or, instead, are they sensitive to temperature fluctuations in the environment, which can cause temperature fluctuations in a circuit?
Your question is too non-specific for a good answer. In general yes to all those questions. But whether these sensitivities and fluctuations are big enough to make a difference in the case you are thinking about, we can't say.
If you add more detail to your question, we may be able to give a better answer.
What is a temperature fluctuation in a circuit?
As anorlunda says, we need much more information to be able to help you out. :smile:
Zener diodes are sensitive to temperature change. So for example, if a zener were used as a regulator, or as a reference for a regulator, it will influence the voltage regulation of that specific rail.
Resistors and capacitors are also sensitive to temperature change, but this is much more attributed to their properties (as indicated on manufacturer spec sheet). Like a resistor has a temperature operating range and will have different resistance according to its properties.
The regulation issues will generally show up as voltage related and not so much show itself as an effect on current draw.
Another aspect is the proximity of heat generating components from the power supply to the circuit. If the circuit is co-located with the power supply, there will be a heat interaction between the two. How much that affects the circuit will depend on how close heat/EM generating are to other more sensitive components.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
