Can Someone Help with Gaussian Beams?
  • Thread starter Thread starter Green Lantern
    Beams Gaussian
Green Lantern
3. A laser scientist tells you that her He-Ne laser can be focused to a spot size of 5.00 microns. When pressed for details, she tells you that she got this number by measuring the Full Width Half Maximum (FWHM) of the intensity profile of the laser waist.
a) What is w(0) for this laser?
b) What fraction of the laser intensity is contained within the FHWM?
c) At what (full) angle will the beam spread over large distances, if one continues to measure the width of the laser beam to be the FHWM of the intensity?
[PLAIN]http://www.zemax.com/kb/content_images/fwhm/Equation1.jpg
[URL]http://upload.wikimedia.org/wikipedia/commons/thumb/5/53/GaussianBeamWaist.svg/350px-GaussianBeamWaist.svg.png[/URL]
From previous experience in a laboratory I know that the wavelength of a He-Ne laser is about 633 nm. I don't know if I can assume that for the purposes of this question. I'm using Laser Electronics 3E by Joseph Verdeyen and the book doesn't do a good job of explaining full width half maximum intensity. There's also no sample problems in the book or examples so I really can't tell if I'm doing it right. I don't know either z or z(R), although I can express z(R) in terms of w(0), but I don't know that quantity either. The equation for intensity above didn't come from my book. At least I didn't see it there. Am I supposed to use the 0.5 microns as w(z) for the intensity equation here?
I'm just going to bump this topic.
What does w(z) represent? I assume it's some sort of measure of the width of the beam, but how is it defined exactly?
The book here gives w(z) as the spot size. There is a minimum spot size at a certain point along the z-axis defined as z=0.
It's defined by this equation given in the OP:
[PLAIN]http://www.zemax.com/kb/content_images/fwhm/Equation1.jpg[/INDENT]
where I0 is the intensity at r=0. I0 and w are both functions of z. At the beam's focus, w takes on it's minimum value, denoted by w0.
Green Lantern, if you set I=I0/2 in that equation, you can determine what r is at the half-maximum points.
Yes, that is a reasonably valid assumption.​
Great. Thanks for the help.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
