Can someone helpme with this question
  • Thread starter Thread starter jlmac2001
The discussion focuses on deriving the relationship between force and velocity for a charged particle in a magnetic field using the Lorentz force equation. It emphasizes that the force acting on the particle is perpendicular to its velocity, which can be shown by taking the derivative of the dot product of velocity with itself. Participants are encouraged to apply the product rule for differentiation to find the necessary relationships. The conversation highlights confusion around the mathematical steps involved in this derivation. Understanding these concepts is crucial for demonstrating that both force and velocity maintain constant magnitudes.
jlmac2001
The force acting on a moving charge particle with mass m and charge q in a magnetic field B is the Lorentz force F= q(v x B), where v is it's velocity. Suppose thata particle moves in the (x,y) plane with a uniform B field in the z direction. Assuming Newton' second law, mdv/dt = F, show that the forceand velocity are perpendicular, and that both have constan magnitude. Hint: Find (d/dt)(v dot v).
I don't know where to start. How do you take the derivative of v dot v?
Use the product rule:
<br /> \frac{d}{dx}( f \cdot g ) = f \cdot \frac{dg}{dx} + \frac{df}{dx} \cdot g<br />
still don't get it
Can you elaborate? I don't understand.
