Can someone solve this complex number equation for x and y
The discussion focuses on solving the complex number equation (ix)(1+iy)=(3x+i4)/(x+3y) for real quantities x and y. Participants share methods for isolating x and y by equating real and imaginary parts after rationalizing the fractions. Two polynomial equations are derived: yx^2 + 3y^2x - 3x - 3xy^2 = 0 and x^2 + 3yx - 4 - 4y^2 = 0. A suggestion is made to express y in terms of x as y=(3/4)x to simplify the equations further. The conversation emphasizes various approaches to solving the complex equation effectively.
anjunawoop
If x and y are real quantities what are the solutions for x and y
I have tried grouping the equation into two equal complex numbers but have failed to find a solution which isolates x and y from the two quite long polynomial equations.
Does anybody know how to do this.
Your approach sounds fine. Show us what you did so far.
(xi)/(1 + yi) = (3x + 4i)/(x + 3y)
First rationalized the left hand fraction.
(xi)/(1 + yi) * (1 - yi)/(1 - yi) = (xi -yxi^2)/(1 + y^2)
= (yx + xi)/(1 + y^2)
Grouped real and imaginary terms
[ yx/(1 + y^2) ] + [ x/(1 + y^2) ]i
Then grouped real and imaginary terms on the right hand fraction
(3x + 4i)/(x + 3y) = [ 3x/(x + 3y) ] + [ 4/(x + 3y) ]i
Set the two complex numbers equal
[ yx/(1 + y^2) ] + [ x/(1 +y^2) ]i = [ 3x/(x + 3y) ] + [ 4/(x +3y) ]i
Take the two imaginary parts to be identical
Take the two real parts to be identical
[ yx/(1 + y^2) ] = [ 3x/(x +3y) ]
[ x/(1 + y^2) ] = [ 4/(x + 3y) ]
Expressing both fractions as polynomials
(yx)(x + 3y) = (3x)(1 + y^2)
(x)(x + 3y) = (4)(1 + y^2)
Then multiplying out both equations in x and y
1. yx^2 + 3y^2x = 3x + 3xy^2
2. x^2 + 3yx = 4 +4y^2
Grouping terms on one side to form two equations that equal zero.
1. yx^2 + 3y^2x - 3x - 3xy^2 = 0
2. x^2 +3yx - 4 - 4y^2 = 0
Now trying to find some way of dealing with these terms.
Hmm, let's just cross multiply and simplify:
(xi)(x + 3y) = (3x + 4i)(1 + yi)
x²i + 3xyi = 3x + 4i + 3xyi - 4y
x²i = 3x + 4i - 4y
(4y-3x) + (x² - 4)i = 0
That doesn't look so bad does it?
I suspect you made a mistake somewhere, but I haven't figured out where yet.
Note that you can write these two equations as
\begin{align*}
\frac{x(x+3y)}{1+y^2} &= \frac{3x}{y} \\
\frac{x(x+3y)}{1+y^2} &= 4
\end{align*}So you have y=(3/4)x. You can plug use that to eliminate y in one of the equations and solve for x.
Or you can do it the way ILS did it.
