How Is the Sum of Squares Formula Derived Using Induction?
  • Thread starter rsala004
  • Tags
    Induction
In summary, the formula for finding the number of squares in a nxn box is (n)(n+1)(2n+1)/6 and this can be proven using the concept of induction. First, the base case is shown to be true, and then by manipulating the formula, it can be shown to be true for all positive values of n.
rsala004
23
this is to figure out formula for how many squares you can find in a nxn box.
12+22+32+...+N2
Can someone show steps to how a simplified formula can be found? ( i only know the concept of induction, not how to do it really..)
it is (n)(n+1)(2n+1)/6 , but how is this accomplished
thanks a lot, would be great if some work was shown.
Mathematics news on Phys.org
12+22+32+...+N2
What is the context of the question? Is this for school work?
First show the base case:
1^2 = 1
Then assume:
[tex]1^2+2^2+\cdots+n^2 = \frac{n(n+1)(2n+1)}{6}[/tex]
Now add [itex](n+1)^2[/itex] to get:
[tex]1^2+2^2+\cdots+n^2+(n+1)^2 = \frac{n(n+1)(2n+1)}{6}+(n+1)^2[/tex]
Now your task is do manipulate the right hand side to get:
[tex]\frac{n(n+1)(2n+1)}{6}+(n+1)^2 = \frac{(n+1)(n+2)(2n+3)}{6}[/tex]
which would prove the induction hypothesis that if the formula is true for n, then it's true for n+1.
If you do this you show the theorem true for n=1 and therefore also by n=2, and therefore also for n=3, and therefore also for n=4, ... So by induction you have shown it true for all positive n.
Related to How Is the Sum of Squares Formula Derived Using Induction?
1. Can you explain the concept of induction and how it can be used to solve problems?
Induction is a logical reasoning process where one makes generalizations based on specific observations or evidence. In problem-solving, it involves using known examples to make predictions or conclusions about the general case.
2. Is induction a reliable method for solving problems?
Induction can be a reliable method for solving problems, but it also has limitations. It is important to use proper logic and evidence to support the conclusions made through induction.
3. Can induction be used in all fields of science?
Yes, induction can be used in all fields of science as it is a fundamental method of logical reasoning. However, the application of induction may vary depending on the specific field and type of problem being solved.
4. Are there any alternative methods to induction for problem-solving?
Yes, there are other methods of reasoning and problem-solving, such as deduction, abduction, and analogy. Each method has its strengths and weaknesses, and the most appropriate one should be chosen based on the specific problem at hand.
5. How can I improve my skills in using induction for problem-solving?
Practice and exposure to different types of problems and scenarios can help improve one's skills in using induction for problem-solving. Additionally, understanding and applying proper logic and critical thinking can also enhance one's ability to use induction effectively.
  • General Math
9K
  • General Math
  • General Math
  • General Math
  • Electromagnetism
  • General Math
