Can the term distortion be used interchangeably?
  • Thread starter Thread starter StarsFly
    Term
The term "distortion" encompasses various forms of waveform alteration, including amplitude distortion, jitter distortion, and speaker distortion. While a clipped signal is a specific type of distortion, it is not the only one; distortion can occur even if the original signal remains intact. Distortion arises when the output response of a speaker alters the sound, regardless of the signal's condition before reaching the speaker. Additionally, frequency components that deviate from harmonics of the fundamental signal are classified as noise, which can also be related to distortion. Overall, distortion can be broadly defined as any change in the expected waveform shape at any measurement point.
StarsFly
Can the term "distortion" be used interchangeably?
Clipped sine wave = distortion
Assume I run a 30hz tone through one of my dedicated mid-range loudspeakers. There's no doubt that the loudspeaker would bottom out. People often call this distortion. But the signal never clipped. It's the loudspeaker that's distorting.
I assume distortion can be classified into...?
"... interchangeably" with what?
Anything that is distorted.
If the signal is not distorted when it arrives at the speaker, then the term "distortion" does not apply to the signal. But the signal response of the output (speaker) may, yet, distort the sound. That is still distortion.
A clipped signal is only one form of distortion - it's a very broad term.
Distortion means anything different (about the waveform shape) than what you expect wherever you measure it. It can be be amplitude distortion, jitter distortion, aliasing distortion, speaker distortion, frequency response distortion, crossover distortion, whatever. Noise is sometimes considered separately, but not always (noise floor, quantizing noise, whatever).
If you look at the frequency spectrum and the harmonics change in amplitude or phase relative to the fundamental then the signal is distorting.
If additional frequency components appear that are not harmonics of the fundamental then it is called noise.
I think aliasing artifacts are considered distortion and they are not harmonic. I think you can (these days) expand distortion to include any artifacts that are correlated to the input signal.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
