Can the value of pi be found through integration?
  • Thread starter Thread starter AndersHermansson
    Integral
The discussion centers on finding the value of pi through the integral of the function √(1-x²) from 0 to 1, which represents a quarter circle. The integral evaluates to π/4, demonstrating that pi can indeed be derived through integration. A trigonometric substitution, specifically using x = sin(θ), simplifies the integral and confirms the result. Participants also highlight the importance of understanding trigonometric substitutions for evaluating such integrals. Overall, the conversation emphasizes the connection between integration and the value of pi.
AndersHermansson
Is it possible to find an exact solution for this integral?
∫√(1-x*x)dx from 0 to 1
Is it possible to differentiate a root expression?
I found that:
pi = 4 * ∫√(1-x*x)dx from 0 to 1
Mathematics news on Phys.org
the equation is for a semicircle of radius 1 from 0 to 1 you get a quarter circle and 1/4 pi *r^2=1/4pi
1/4pi is the answer
you could also evaluate the integral using a trig subsitution
you already found the answer if you divide both sides of the equation by 4 in your solution you also get the answer
for the trig sub
x=sin(θ)
dx=cos(θ)dθ
substitute into original integral simpligy trig expresion and switch limits of integration (evaluate interms of theta) and you will get &pi/4
if you haven't learned trig subs check it out in your calc book it not a very hard topic.
what is x*? is x a complex variable? i don t quite understand your integral
Probably because it's a lot easier than you're used to. :)
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
