lrubin28 said:
Hi,
In the often cited example of a person in a rocket traveling past Earth at high speed - I think I understand that both the person on Earth and on the rocket could view the other as being the party that's actually moving.
A more precise way of saying this is that in the rest frame of one party, the other party is moving. And Time Dilation applies to the party that is moving according to a frame.
Let me make some spacetime diagrams to illustrate. Here is one showing the rest frame of the rocket covering a time period from -10 years to +10 years. The moment when the rocket travels past Earth, is depicted as the blue dot at the origin of the diagram. The dots represent one-year increments of time:
Notice that the dots are aligned with the Coordinate Time of the diagram which means that there is no Time Dilation because the rocket is not moving in its own rest frame.
Now we can transform the coordinates of the events (dots) of the rocket to see the Time Dilation at a speed of just over 98%c:
Since this is the Earth's rest frame, we can add it in:
lrubin28 said:
And so if they could view the other party, they would both see the other moving in slow motion.
You are thinking that they can each see the Time Dilation of the other party which is not the case. Look at this diagram which shows some of the images of each party as they are propagated at the speed of light to the other party. These are shown as thin lines. I have left off the thick red line that shows the worldline of the rocket since it would obscure the details of the light signals. Just imagine that the red dots are connected by a thick red line:
Look in the lower left corner. You see how the image of the red rocket that is emitted at the rocket's time of -10 years propagates up and to the right and encounters Earth at its time of -1 year. So for the next year on Earth, it will see the approaching rocket go through 10 years of the rocket's clock. This is 10 times fast motion, not slow motion.
Similarly, when the rocket gets to the -1 year, it can see the image of the Earth at its time of -10 years and it will see the Earth at ten times fast motion as they both approach the origin where they pass each other.
But after they pass each other, things change dramatically. Now they each see the other one in slow motion but still it is not the rate of Time Dilation which is about 1/5. Instead, they see each other at 1/10. It takes each of them 10 years according to their own clock to see 1 year pass on the other ones clock.
lrubin28 said:
And I guess there is an assumption that time is relative to the observer. So if the rocket travels 10 years at speed near c, and then turns and spends another 10 years getting back to Earth, those 20 years in space may reflect say 100 years on earth. The original Earth person will be 100+ years old, and the space-person 20+ years old. But if time were relative to the other originally, now it seems that Earth time has become an absolute reference frame. I feel like I'm totally comparing apples and oranges, but can't figure out why. Does this make sense (my question)?
Let's depict this with a couple more diagrams. They both show the rocket traveling away for 10 years and then traveling back for 10 years while Earth accumulates 101 years (instead of 100 years as I wanted to make the light signals line up better). The first diagram shows how the rocket views the Earth's time:
Notice how during the first 10 years of the rocket's clock, it sees Earth aging by only 1 year, just as in the previous diagram but when the rocket turns around, it immediately sees the Earth aging at 10X high speed so that during the second 10 years of the rocket's clock, it see Earth aging by 100 years for a total of 101 years.
Here's the same scenario but showing how Earth views the rocket's clock:
Notice how the first ten years of Earth time is just like two diagrams ago. Earth is seeing the rocket's clock running one-tenth of its own time but this keeps up for 100 years of Earth time during which it sees the rocket aging by 10 years. Then it sees the rocket turn around and for the last year of Earth time, it sees the rocket's time at 10X and so it completes the total aging for the rocket at 20 years.
Does this help you understand Time Dilation?
