Can Transfer Function Include Distrubance Variables?
Transfer functions can include disturbance variables, but this complicates the analysis. One approach is to treat the inlet concentration as a disturbance variable and the inlet flow rate as a manipulated variable, though this requires linearizing the differential mass balance. Some peers suggest avoiding disturbance variables altogether to simplify the transfer function. A transfer function typically represents the output-to-input ratio with disturbances set to zero, while a separate disturbance transfer function can be derived by setting the signal input to zero. Understanding both functions is essential for analyzing disturbed systems effectively.
JeweliaHeart
Problem statement is attached...
my attempt at solution is also attached...
One of my assumptions was to treat the inlet concentration as a disturbance variable, and inlet flow rate as a manipulated variable...However, as I try to solve for the transfer function, it is becoming highly complicated. I am having to linearize the differential mass balance first. Some of my peers said they avoided this by not including disturbance variables in the transfer function. Which approach is correct?
Please, can you provide a block diagram of the sysytem you are trying to analyze?
In this case, it would be much easier to help you.
Preliminary answer: A transfer function is the output-to-input ratio with input=desired signal input (setting all disturbances to zero).
As a second function you can set the signal input to zero and find the "disturbance transfer function",
A disturbed system always has at least two transfer functions: (a) signal and (b) disturbance.
