Can u simplify this further? (25-x) / (-25-x)
  • Thread starter Thread starter punjabi_monster
    Simplify
The expression (25-x) / (-25-x) cannot be simplified further because it involves subtraction, which requires a common factor for simplification. Simplification is only possible when both the numerator and denominator are single terms that can be factored. If the expression were (25-x)/(x-25), it could be simplified to -1. Therefore, the original expression remains as is. Understanding the conditions for simplification is crucial in algebraic expressions.
punjabi_monster
can u simplify this further?
(25-x) / (-25-x)
thanks.
No.
It is subtracting, therefor it would need to be a multiple of, in order to be able to simplify. If the both the top and bottom were multiplying(1 term in each denominator and numberator) then yes, you would be able to simplify.
Bottom line, no, when more than one term, it has to be perfect in order to simplify.
ok thanks.
IF the problem were (25-x)/(x-25) then it would be -(x-25)/(x-25)= -1.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
