Can voltage appear out of the blue?
  • Thread starter Thread starter flyingpig
    Voltage
The discussion revolves around a lab problem involving two uncharged capacitors connected in series to a 10V power supply. The user initially calculated the expected voltages across the capacitors but measured 4.4V and 5.6V instead of the predicted 4V and 6V. Participants pointed out that capacitors can retain residual charges and may self-charge over time, which could explain the unexpected voltage readings. They also emphasized the importance of ensuring the capacitors were truly uncharged before the experiment and discussed the correct equations for calculating voltages in series circuits. Ultimately, the user was reassured that the measured voltages were plausible given the circumstances.
flyingpig
This is a lab problem, I sort of got an idea, but the instructions are holding me back from answering it properly
Instructions in manual said:
If two capacitors with different nominal capacitances, C1 and C2 (both initially uncharged) are connected in seris with a power supply set to some 10.0V. What will the voltage across each capacitor be?
Alright I can do the math, but in reality something is wrong with my data
flyingpig's data said:
C1 = 3300uF
C2 = 2200uF
V1 = 4.4V
V2 = 5.6V
Predictions using math
V1 = 4V
V2 = 6V
So what is the problem? The capacitors were not charged, how did I manage to get 4.4V and 5.6V? I must have charged it up right? I know this is a stupid question but I need some confidence.
What method did you use? You need to use the equation that relates capacitance, voltage and charge...
What do you mean "method", do you mean the prediction or the actual hands on measuring?
Yeah, I just wanted to see the math you used for the predictions. If the math is right, then something must have been going on with the measurements.
Series, so \Delta V = \Delta V_1 + \Delta V_2 and Q_{net} = Q_1 + Q_2
C_{eq} = \frac{1}{C_1} + \frac{1}{C_2}
C_{eq} = \frac{1}{3300} + \frac{1}{2200} = 1320uF
Q_net = 1320uF/10V = 132uC
\Delta V_1 = 132uC/3300uF = 0.04
Wait...one second.. something is wrong with my units...
It's not clear what it is you're problem is. The procedure said to charge the series connected capacitors via a 10V supply, and you're complaining because they got charged? :confused:
But they are just connected, it doesn't mean they are charged right...? Or in fact they are charged indirectly...?
What procedure did you follow to make sure that the capacitors were initially uncharged? Capacitors can hold a charge for quite some time, and may have a residual charge from some other experiment(er).
Did you take note of the capacitor's value tolerance? It's usually marked on the body of the capacitor in some fashion.
Electrolytic capacitors have been known to self-charge to some extent over time (it's a quirk of the chemistry of the electrolyte and the plates).
We touched the leads of the wires to uncharge it
Should be: [/color]Q_{net} = Q_1 = Q_2
Should be: \frac{1}{C_{eq}} = \frac{1}{C_1} + \frac{1}{C_2} [/color]
Not just your units...
C_1 \Delta V_1 = C_2 \Delta V_2
C_1 (10V - \Delta V_2) = C_2 \Delta V_2
\frac{3300uF}{2200uF} = \frac{V_2}{10V - V_2}
1.5(10V - \Delta V_2) = \Delta V_2
\Delta V_2 = 6V
10V - 6V = \Delta V_1 = 4V
There we go
