Can we calculate the Schwarzschild radius of an object without knowing its mass?
The discussion centers on the detection methods of black holes, specifically gravitational lensing, x-ray detection, and accretion discs. The original poster seeks reliable resources and detailed theories for these methods as part of their coursework. They also inquire whether the Schwarzschild radius can be calculated without knowing an object's mass, which is confirmed to be impossible since the radius is defined by a mass-dependent formula. Participants share insights on how black holes are inferred through observations of binary star systems and the dynamics of stars near supermassive black holes. The conversation emphasizes the complexities of black hole detection and the importance of mass in calculations related to their properties.
mrsmeath
I've got a coursework to get done on the detection methods of black holes. So far I'm aware of gravitational lensing, x-ray detection and the accretion discs, and have just about finished my section on gravitational lensing. I'm wondering though if anyone has some (reliable) links or good insight into the detailed theories and formulae (no matter how complicated) behind the last two. It's a teach-yourself research coursework for college, thus feel free to assume i know nothing and want to know everything - you'd be right to do so! :shy: thanks!
EDIT: Oh, and does anyone know of a method which can calculate the Schwarzschild radius of something without knowing its mass? sounds unlikely to me from what i know about it but maybe I am wrong...
Astronomy news on Phys.org
I saw a documentary in which they showed a video of stars near our galatic center whipping aroung so fast around something they could not see, that it must have been a black hole.
taa guys, never considered the signature a black hole would make being created so thanks chronos - uve probably added another few pages to my coursework :approve: I've got till thursday morning so if anyone else can plant a few more seeds of wisdom, id appreciate anything u can throw me (i like working till the last minute) :biggrin:
It's not a full answer, but check out this thread if you haven't already.
Really, you're asking a big question, as black holes play a huge role in modern astrophysics...which is funny, because we're not 100% sure they exist! What we do know is that there are several places in the universe in which there's a lot of mass compacted into a very small space (by astrophysical standards).
Here is a nice link on stellar mass black holes. The basic idea is that we observe systems of binary stars and determine the parameters of the system (masses, velocities, radii, etc.) based on various measurements. If we determine that one component of the system is very massive (greater than three times that of the sun) but isn't giving off any light, we assume that it's a black hole. There are various physical reasons for that assumption that I can go into in more detail on if you like.
Another place we see black holes is at the centers of galaxies and we call these supermassive black holes (SMBHs). Most of the ones we've seen so far are greater than a million times the mass of our sun, though they can get up to a billion solar masses. The way we measure these masses is similar; that is, we look at the motions of stars near the black hole and use Newtonian gravity to infer a mass for the object.
We assume that these are the same objects that produce quasars (or, more generally, active galactic nucleii), partially because they're in the same location (the centers of galaxies) and partially because we can't think of anything else that could steadily produce that much light. To infer the masses of these objects, we can't use dynamical measurements (the quasars shine so brightly that the nearby stars are difficult to see). Rather, we infer a mass based on the luminosity. I suggest looking into something called the "Eddington Luminosity", because it gives a rough limit for the luminosity of an object of a given mass. When an object exceeds this luminosity limit, the radiation pressure becomes so strong that the object has a tendency to blow itself apart. In the case of black holes, it's not the black hole itself that would be blown apart, but rather the material accreting around it.
Well, the Schwarzschild radius is defined by:
r_g = \frac{2GM}{c^2}
so it doesn't make sense to calculate it without a mass (or a set of equivalent parameters).
thanks for the link/info tiger, and i was hoping that would be the response to my schwartz radius question :) do'nt worry about more detail in the 3 or greater solar masses = black hole, think I've got that side covered so far :) taa again
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
