Can you detect the Earth's Rotation Using a Hockey Puck on Ice?
  • Context: Undergrad
  • Thread starter Thread starter fahraynk
    Ice Rotation
The discussion centers around the question of whether a hockey puck placed on a flat ice rink can exhibit movement due to the Earth's rotation. Participants explore the theoretical implications of this scenario, considering factors such as forces acting on the puck, the role of friction, and the effects of latitude.
  • Some participants question the definition of "move" and suggest that a more specific question is needed regarding the puck's motion relative to the ice.
  • One participant argues that the puck would not move on the ice, while others propose that Coriolis forces could cause a spiral path at the North Pole.
  • There is discussion about the centrifugal force due to Earth's rotation and its dependence on latitude, with some suggesting that this force could be significant enough to affect the puck's motion.
  • Concerns are raised about the influence of friction and impurities on the puck's movement, with some doubting that Coriolis force would dominate in a real experiment.
  • Participants explore the idea of tilting the ice rink to maximize the effects of Earth's rotation, discussing the implications for the puck's motion and the necessary conditions for observing any movement.
  • Some participants mention that the ice would have already experienced the same forces as the puck, complicating the measurement of any movement.
  • There is a suggestion that modeling the puck's behavior could be akin to a gyrocompass or a Foucault pendulum, depending on the setup.
Participants express a range of views on the puck's potential movement, with no consensus reached. Some believe that movement could be detected under specific conditions, while others maintain that the puck would not exhibit noticeable motion due to various factors like friction and impurities.
Participants note that the discussion involves assumptions about the ideal conditions of the ice and the puck, as well as the complexities introduced by real-world factors such as friction and the tilt of the ice surface.
fahraynk
TL;DR
Dynamics question about seeing things move due to Earth's rotation
If you put a hockey puck on a flat Ice rink, will it move due to the Earths rotation? For example, if I make a mark and measure the distance moved with a caliper, would I notice a change?
Define "move" please. If the Earth is rotating we are all "moving". You need to ask a more specific question I believe.
Can you detect Earths Rotation Using Ice Field? Yes.
I wrote in original question if you could measure distance moved by the puck due to rotation of the Earth with a caliper. So by that I mean the puck moving in the frame of the ice field by gaining acceleration due to rotation of Earth.
If the puck is moving, say, at the north pole (good place for ice sheets!) there will be "coriolis forces" causing the path on the ice to be a spiral. Actually the puck will travel "straight" and the Earth rotate under it. This assumes frictionless ice but I feel certain one could actualize this with a very heavy puck and very good ice.
At other latitudes there are similar effects although smaller and the ice more difficult to chill.
How fast do you think the puck will move with respect to the ice? (The Earth spins at around 1000 miles per hour)
fahraynk said:
Summary: Dynamics question about seeing things move due to Earth's rotation
It works a lot better if you use rocks in the desert...
https://www.nationalparks.org/connect/blog/sailing-stones-death-valley
  • Haha
russ_watters said:
I don't see why the puck would move on the ice.
There are two questions to answer. 1. Is there a force and 2. is there a situation where the friction forces are less than that force.
There will be a centrifugal force due to the Earth's rotation, and the horizontal component will depend on the observer's latitude. (Enough to make it an oblate spheroid - so it is significant.)
I think the coefficient of friction would need to be lower than ice on ice. You'd need to look at the angle of a suspended mass, perhaps. But local gravitational field variations could well be greater so could you even measure it?
… wait a couple of years …
Still though, I have a hard time imagining the Coriolis force becoming the main contributor to deviation from straight motion over impurities, puck rotation and friction, etc, in a real experiment.
The horizontal component will be zero by definition of horizontal as orthogonal to the gravitational field in the local rest frame. In other words, if you freeze over a pond, the component of acceleration in the ice plane will be zero.
The effect you are considering here would be accounted and corrected for in the buildup of the ice sheet.
With respect to a fixed point on the earth, the Coriolis force is zero. The Centrifugal force is an [itex]\Omega \times (\Omega \times R)[/itex] acceleration. However, only a small component points towards the equator - it is mostly up. Further, the ice felt this force when it froze, so the puck needs to move 'uphill' with exactly the same resistance needed to cancel this force. This will be approximately the thickness of the ice sheet divided by the radius of the earth.
(Your) good thinking and my sloppy thinking . So the water / ice will have already experienced the same effect as the puck. But say the ice rink were tilted, after freezing, to be parallel with the equatorial plane. That would give the maximum effect. Whoops, the angle of g would also be changing. So go to near the North Pole and g would be normal to the centrifugal force and ignore the cos(small angle) factor at 1km from the pole.
a = ω2 r
= 1.3e-10 X 1e3 ms-2
and g = 10ms-2
That would imply a coefficient of friction less than 1.3e-8
Pretty slippery.
While this is true for a stationary puck, it will not be true for a moving puck. Hence why I discussed deviation from a straight line and not motion in itself.
a = ω2 r
and g = 10ms-2
Pretty slippery.
If you know the exact angle to tilt you already know that the Earth is spinning. You cannot ignore the small deviation from the cosine. The effect is of magnitude 1/(2*6700^2) ~ 1e-8. It is the same as what you are trying to probe.
Assuming that "on ice" means floating without friction.
At the equator, it would remain flat and so not move relative to the Earth.
At the poles, it would continue to rotate with the Earth.
I think that, in between, you could model the puck as the slow rotor in a gyrocompass, but with a vertical, not a horizontal axis. Maybe like a Foucault pendulum.
Orodruin said:
The linked article seems to suggests the motion is due to very particular weather effects, not due to Earth’s rotation.
I debated whether to add a winkie emoji to my post...
You university professors are so serious and literal... :wink:
  • Haha
I debated whether to add a wink emoji...
You just can’t tease us with what would be very cool stuff based on physics that upon examination is just cool stuff based on meteorology
Edit: … except professors in meteorology I guess …
The word meteorology itself is such a tease. Turns out it has very little to do with actual meteors …
  • Haha
That is true, but if you're going to have a moving puck, why not a cannon? :smile:
Oh, also the puck has a height - so it's center of mass is slightly too high relative to the velocity of the base.
Yeah for the specified hockey puck. Maybe some giant curling stones at high speed (with lots of broomsters). The ice would be perfect (by stipulation).
360 degrees per 23.9 hours. 0.1 degrees per 23.9 seconds. That sounds do-able. No need for high speed. The deflection angle get larger when the trajectory takes longer.
You control for any systematic error due to a side-ways tilt of the ice by running the puck both ways. Coriolis will cause a rightward deflection both ways. A tilt would cause a rightward deflection one way and a leftward deflection the other.
There are tides to consider.
Water slops along in tandem with the moon and sun.
It takes The mass of a whole ocean and the right underwater topography to get measurable tide.
The Great Lakes tidal height is about 5 cm.
Prevailing winds are generated by the atmosphere 'slipping' in regard to the rotation of the earth.
Again, massive amounts of mass.
I doubt that the mass of a hockey puck, even sitting on a perfectly frictionless surface in vacuum will move enough to be measurable, and if it did, you might not be able to sort it out from tidal effects.
Also, take your experiment up to geosynchronous orbit. Put the puck on the frictionless surface at rest. Both are being pulled by gravity. Both are rotating around the center of the Earth at the same speed. Both stay at the same point over the Earth's surface. The puck is an inch high, so if the frictionless surface is closer to the earth, then the puck's center of mass will be ~1.75 cm farther from the center of the Earth than the frictionless surface. You can do the Newton's classical force calculation for that. A relative force difference compared to the frictionless surface will exist, but it is going to very, very, very, very small. If you waited for long enough, you would eventually wind up a with measurable distance the puck moved relative to the surface.
If other effects like tidal forces don't swamp it.
How would you separate the effect of the 'sideways tilt' and the centrifugal force? What would be the reference level to determine tilt?
There's some pretty dubious fictitious force analysis going on in this thread, and the OP doesn't seem interested any more.
Anyway, to pick up on a couple of recent points:
The force you have just described includes the tidal force.
In exactly the way described you can't: centrifugal force forms part of the tilt (unless it is perfectly balanced, in which case there is no tilt).
The geoid, by definition. Alternatively, the surface of a bucket/swimming pool/sea/ocean of water.
No need to distinguish. The intent is to measure Coriolis. Both tilt and centrifugal force result in a consistent sideways deflection in a single direction (e.g. southward). Coriolis delivers a sideways deflection that reverses when the puck traverses the track in the opposite direction (e.g. rightward).
The obvious way to obtain level ice is to start with water in a large flat rink. It'll naturally relax to become level. Then you freeze it. The tilt will naturally compensate for any centrifugal force.
[Then you scribe a fine line on the edge of the rink right at the surface of the ice. You label this line with the letter C. This will be referred to as "C level"]
  • Haha
In this experiment we can't actually measure the tilt because the angle is small and the ice is flat over only a few metres max. The principle of equivalence tells us that acceleration and gravity are indistinguishable so how can you know if the force in one direction is due to the g component along the slope or the centrifugal force.
This thread is about the feasibility of a particular experiment. I still say that the quantities involved are way too small.
Again, we are not attempting to measure either tilt or centrifugal force. We are attempting to measure Coriolis.
No, I think the principle of equivalence tells us that 1: acceleration and 2: the net of gravity and centrifugal force are indistinguishable.
You calculate the constituents of ## g = \dfrac{GMm}{r^2} - r \omega ^2##.
The first post doesn't mention motion of the puck. But threads tend to change directions on the way.
pbuk said:
You calculate the constituents of g=GMmr2−rω2.
Aren't we dealing with vectors here?
Well yes but we can analyse their components separately. By definition g is normal to the geoid. Centrifugal force is measured parallel to g, the component of intertial forces normal to g is Coriolis force.
  • · Replies 16 ·
  • · Replies 47 ·
  • · Replies 19 ·
