Can you stable out a 12v dc pulse?
A user is seeking to stabilize the pulsed output from a 12v magneto for use in a go-kart's turn signals and brake lights. Suggestions include using a diode and capacitor to convert the pulsed output into a steady DC current. The discussion also mentions the effectiveness of a bridge rectifier and a large capacitor to achieve this goal, referencing techniques used in vintage motorcycles. The user plans to incorporate LEDs and a timer circuit for proper blinking speed. Overall, the conversation focuses on methods to effectively utilize a magneto as a reliable power source for lighting applications.
pickerguy
Hey guys. I made myself a pulse circuit but my power supply failed.
Now I need a way to use a 12v magneto as a power supply.
But a magneto puts out pulses. Can I put a capacitor or a diode there to make it a steady stream of dc current?
This is for my go kart 5hp briggs. for turn signal and brake light
Are your turn signals tungsten lamps or LEDs? Is there any reason pulses won't work? Yes you can use a diode and capacitor very effectively.
edit: id like to still use Leds and my timer circuit to get the blinker speed correct and use the magneto as the power scource
LEDs still sorry wasnt thinking straight
look at the battery charger coil on any electric start lawnmower engine.
one of those plus a bridge rectifier and huge capacitor will do what you want. 1950's British motorcycle guys used this technique to avoid having a battery. look up how a magneto works...
For what purpose was this magneto, originally? What information does it provide on the plate?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
