The discussion revolves around the feasibility of using resistance to control the output of a 10SI Delco alternator to achieve a fixed current of 2 amps. Participants explore various methods of regulating the alternator's output, including the implications of omitting components like the diode trio and voltage regulator, and consider practical applications and experiments related to this setup.
- Exploratory
- Technical explanation
- Debate/contested
- Experimental/applied
- One participant suggests that placing resistance between ground and the brushes could potentially allow the alternator to charge at a fixed 2 amps, but expresses skepticism about the practicality of this approach.
- Another participant notes the importance of the diode trio for sourcing current for the field and emphasizes that without it, the output would be limited.
- A different viewpoint proposes using a 1964-1969 Chrysler electromechanical voltage regulator as a simpler alternative, which acts like variable resistance to ground.
- One participant suggests using a constant current electronic regulator after the voltage regulator as a more straightforward solution than a mechanical speed regulator.
- A schematic is proposed by a participant, indicating that starting with a 10k resistor might be a reasonable approach, but acknowledges that the resistor's value will affect the output power.
- Another participant counters that a 10k resistor may not provide sufficient field current and recommends experimenting with various bulb sizes to find suitable resistances.
Participants express differing opinions on the effectiveness of using resistance to control the alternator's output, with no consensus reached on the best approach. Some suggest alternative methods and components, while others question the practicality of the proposed solutions.
Participants mention various assumptions regarding the operating conditions, such as the need for constant speed and voltage, as well as the limitations of using resistors in this context. The discussion also highlights the dependence on specific components and configurations, which may affect the outcomes.
