Explaining the Physics of a Rolling Cannon
The discussion explains the physics behind a rolling cannon firing a cannonball, emphasizing the law of conservation of momentum. When the cannonball is fired, both the cannon and the cannonball have equal magnitudes of momentum but in opposite directions. The cannonball's smaller mass allows it to achieve a higher velocity compared to the cannon's larger mass, resulting in a modest recoil. It is clarified that while the momenta are equal in magnitude, they are not equal as vectors due to their opposite directions. This illustrates the relationship between mass and velocity in momentum conservation.
eraemia
Imagine a cannon that is free to roll on wheels. Initially, both the cannon and cannonball are at rest. When the cannonball is fired, though, the momentum transferred to the cannonball comes at the expense of the cannon, so the cannonball and cannon end up with momenta having equal magnitudes but opposite directions. If this is so, why does the cannonball fly away at a large speed while the cannon recoils only very modestly? Explain your response.
Law of Conservation of Momentum
Newton's Third Law
According to the law of conservation of momentum, the momentum of the canon would equal the momentum of the canonball. Since momentum is mv, the cannon's large mass would account for its smaller velocity/recoil, compared with the canonball's smaller mass and greater velocity. Is this right? What am I missing?
I don't think you're missing anything. Your answer is correct. Except that where you said "the momentum of the canon would equal the momentum of the canonball" you should take care to note that they are in opposite direction and so momentum (a vector) is not equal, but only equal in magnitude.
