Cant understand some step in a solution
  • Thread starter Thread starter nabliat
nabliat
here is the problem and solution:
http://i26.tinypic.com/2vvm8vm.jpg
http://i31.tinypic.com/nqwq4n.jpg
i solved the 1st subquestion.
my problem starts with the second subquestion:
i understood how they got this expression
E=\frac{\epsilon_0}{\epsilon}E_0
but i don't know what they do next
what law principle are they doing in the next 3 lines??
why the integral equals the expression that they show??
replied in a wrong place
The principle is that the electric field can be derived from the electric potential
\vec{E} = -\vec{\nabla U}
from which it follows that
V =-\int\vec{E} \cdot \vec{d \ell}
The line integral is taken along a straight line from one plate to the other and needs to be split into two terms because the E-field changes when the dielectric-vacuum boundary is crossed. That's why you get two terms with two different E values.
Does this make sense?
this means that the field is the divergent of the potential
why are we starting to look for the potenitial
we are asked to find the total field
in the result i was not presented with the total electric field
but with sepated fields that i knew them already before the integral part
My explanation was how they got equations (7) - (9). They did the line integral in two steps because there are two different electric fields between the plates. After doing the integral, they solve the equation to find E0 in terms of the voltage, which we assume is a given quantity. Once you have E0, you can find E.
ok thanks :)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
