Can anyone explain the derivation of the formula for cantilever oscillations?
The discussion centers on the derivation of formulas for cantilever oscillations, specifically T=2(pi)*[(4ML^3)/(bd^3E)]^1/2 and h=4MgL^3/Ebd^3. The original poster is conducting an experiment to measure oscillation periods and heights by varying mass and cantilever length. They seek clarification on how these formulas are derived, referencing concepts from Hooke's law and simple harmonic motion. The conversation concludes with an explanation of the relationship between the derived formula for period and the motion's simple harmonic nature.
ash1098
[SOLVED] Cantilever Investigation
1.Hi,
I am writing a report on cantilever oscillations, my experiment involves fixing different cantilvers e.g. a ruler to the end of a table then measuring the period and height of oscillations while varing the mass attached to the cantilever, and other varients e.g. length of cantilever.
2. I have found these two formulae: (Shown much more clearly in attachments)
T= 2(pi)*[(4ML^3)/(bd^3E)]^1/2
and:
h= 4MgL^3/Ebd^3
where:
b= width of cantilever
d= thickness of cantilever
E= Youngs Modulus
M=Mass
L=Lenght of cantilever
T=period of oscillations
h=height of oscillation
3. I have looked at eqn's involving Hooke's and simple harmonic motion but cannot work out how these formulae have been derived.
Does anyone know how these formulae where derived, or where I can find information on this in general?
Thanks.
ash.
p.s. I have written out the formulae using math open office and attached them in pdf if it helps make them easier to read.
Well I have done a lab to find the Young's Modulus of a loaded cantilever and this is theory which is written down on the paper:
The depression,s,due to a load W(=Mg) at the end of a cantilever of length,l, is
s=\frac{Wl^3}{3IE}
This strain brings into play internal stresses which produce a restoring force equal to W, i.e. equal to \frac{3IEs}{l^3}.
If the acceleration of the load \frac{d^2s}{dt^2} when the cantilever is displaced to produce vertical oscillations,then
M\frac{d^2s}{dt^2}=\frac{-3IE}{l^3}s
OR
\frac{d^2s}{dt^2}+\frac{3IE}{Ml^3}s=0
Hence the motion is Simple harmonic and the periodic time,T, is
T=2\pi \sqrt{\frac{Ml^3}{3IE}}
from which
E=\frac{4\pi^2Ml^3}{3IT^2}
For a beam of rectangular section:
I=\frac{bd^3}{12}
I hope that helps in some way
Thanks for your reply rock.freak it's really really useful, just one question:
why does T=2\pi \sqrt{\frac{Ml^3}{3IE}}
Thanks, ash.
Well from
\frac{d^2s}{dt^2}=\frac{-3IE}{Ml^3}s
and that is of the form a=-\omega^2 s where a=\frac{d^2s}{dt^2}
so from that
\omega=\sqrt{\frac{3IE}{Ml^3}}
and since it moves with SHM, the period,T, is given by
T=\frac{2\pi}{\omega}
Oh yeah I see it now, Thanks alot.
Ash.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
