How Does Inserting a Dielectric Affect Capacitor Voltage?
Inserting a dielectric material into a charged capacitor reduces the voltage across its plates while keeping the charge constant. The relationship between capacitance and voltage is described by the equations C2 = KC1 and q = CV, where K is the dielectric constant. To find the new voltage after inserting the dielectric, one can calculate the charge using the initial capacitance and voltage, treating C1 as a known variable. The new capacitance can then be determined, allowing for the calculation of the new voltage. Understanding these relationships is crucial for solving the problem effectively.
rcrx
An empty capacitor is connected to a 12.0-V battery and charged up. The capacitor is then disconnected from the battery, and a slab of dielectric material (K = 2.8) is inserted between the plates. Find the amount by which the potential difference across the plates changes.
C2 = KC1
q = CV
I know that the charge will stay the same and voltage will drop.
I have no idea how to set this up mathematically. This is where I have hit a road block.
You are not give C1, so you must think of it as a "known" that may appear in the answer. From that and one of your formulas, you can calculate the charge.
Great observation to see that the charge remains the same with the dialectric is inserted!
Use the formula with the V in it to find the potential on the cap with dielectric.
Thanks for the reply. But how do I set it up? I am so confused. I know it is simple, but some problems I just can't wrap my head around mathematically.
Any and all help is very much appreciated!
Well, to calculate the charge, I just meant to use your formula q = CV.
To avoid confusion, I would replace C with C1. Put in your potential and you've got an expression for q with no unknowns (except C1, which we are treating as a known for now).
The first formula gives the new C2.
Use the 2nd formula again to find the new V.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
