Is My Capacitor Fully Charged?
A capacitor in a series circuit with a DC voltage source will reach a fully charged state when the voltage across its terminals matches that of the source, resulting in no current flow. While the charge stored in the capacitor increases with a higher DC voltage, the capacitance itself remains constant, defined as the ratio of charge to voltage (C=Q/V). Misunderstandings about capacitance increasing with voltage were clarified, emphasizing that only the charge increases. The discussion concluded with an acknowledgment of this clarification. Understanding these principles is essential for accurate circuit analysis.
Gaurav sandhu
suppose i have a circuit,in which a capacitor and resistances are connected in series with a DC voltage source.
then after a long interval of time we know that capacitor will have same voltage across its terminal as that of DC voltage source and no current flow in the circuit.
so, can i say at that time, my capacitor is fully charged...
Yes, fully charged at that voltage. If you raise the DC voltage, the capacitor can store more charge.
that means capacitance of a capacitor is increases with increase in DC voltage around it !
i think this is not true...
No. The charge stored increases, not the capacitance. Capacitance C is defined as the ratio of charge Q to voltage V. C=Q/V
ok...i got it...
thanks a lot...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
