Capacitor Problem: Work Done by a Battery in Charging
  • Thread starter Thread starter sahil_time
    Capacitor
The discussion centers on the work done by a battery when charging a capacitor in a circuit with no resistance. The initial thought was that the work done equals the energy stored in the capacitor, expressed as 0.5CV^2. However, the correct formula for the work done by the battery is W = QV, which simplifies to W = CV^2. It is clarified that while the energy supplied by the battery is QV, the energy stored in the capacitor is indeed 0.5CV^2, with the other half potentially lost as heat in circuits with resistance. The conversation concludes that energy loss can occur through electromagnetic radiation even in the absence of resistance.
sahil_time
I came across a question in my Physics Paper
"What is the work done by a battery in charging a capacitor" (Assume circuit has no resistance).
This is what i thought...
The Energy in the field between the capacitor plates is 0.5CV^2 where C=capacitance and
V=Battery EMF.So the ans should be 0.5CV^2.
BUT the actual solution in paper was...
Net Work done=Net Charge * Voltage
W=QV
W=CV^2 .
What is the correct ans?
The energy supplied by the battery is E = QV and Q=CV to get E=CV2
the energy stored by the capacitor is E=½ CV2 (if I remember correctly, the other ½ is lost as heat).
It can't be lost as heat...without resistance!
The energy supplied by the battery is Q x V. The energy stored on the Capacitor is 0.5Q x V.
Energy can be lost by
1) Resistance in the connecting wires
2) Sparking when the switch is closed
3) Electro-magnetic radiation from the connecting wires as the charging current flows. The flowing charge is a changing current and a changing current produces electro-magnetic (radio) radiation
In the absence of 1) and 2) there is always 3)
