What are the different methods to measure the resistance of a capacitor?
Razvan
I was told that I can measure the "resistance" of a capacitor using 3 methods:
1. "The direct method"
R = \int_1^2 \frac{\rho}{A} ds
2. "Ohm's Law"
R=\frac{U}{I}
U=\int_1^2 E ds
E=\rho J = \frac{\rho i}{A}
3. "The analogy between electrostatics and electrokinetics"
\epsilon is replaced by \sigma
and
C is replaced by G
What does this really mean, the resistance of the capacitor?
Why is E=\rho J?
What is this analogy between electrostatics and electrokinetics?
It means exactly what it says... probably the easiest way to view it is to look at the Ohm's law approach.
An ideal capacitor has infinite DC resistance ... when an ideal DC voltage source is connected via ideal conducting wires, the charge flows from one plate to the other in zero time giving rise to an infinite current.
This does not happen in real life though.
IRL it takes a finite amount of time for the charges to transfer ...
You should be able to derive that equation ... do you know what the letters stand for?
The analogy in question is just a handy way of getting electrokinetic equations from the static ones.
Most people can remember the electrostatics.
There is series resistance Rs and there is parallel reistance Rp. The former is usually << 1 ohm, the latter >> 1 megohm for say a C = 0.1 uF ceramic capacitor. So we can say that if we apply a voltage V across C then I = V/Rp after a very short time of say 10 Rs*C time constants, maybe 0.1 μs.
The electric field inside the capcitive part of C depends on how it's fabricated. In all cases, ∫Edl = V = Q/C with Q the charge and C the capacitance. Inside Rp we have E = i/σ where i is current density and σ = conductivity of the resistive material for Rp.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
