What Happens When AC Is Applied to a Capacitor?
  • Thread starter Thread starter skylines
    Ac Capacitors
When AC is applied to a capacitor, it charges during the positive half-cycle as the voltage rises and discharges as the voltage drops. The initial voltage (v0) represents the starting point, while vpeak is the maximum voltage reached at 90 degrees, and v1 is the voltage at the end of the positive cycle at 180 degrees. During the negative half-cycle, the capacitor behaves similarly, charging and discharging in response to the alternating voltage. The current in an AC circuit is always 90 degrees ahead of the voltage due to the relationship between charge and current. Understanding these dynamics is essential for analyzing capacitive behavior in AC circuits.
skylines
what happens if AC is applied to a capacitor?
I am able to understand that ,For 1st half of the cycle,i.e for +ve cycle, during the voltage rise from v0 to vpeak, the capacitor charges, and during the voltage drop from vpeak to v1 the capacitor discharges.Let me know if this is true.
I assume
v0 as the intial voltage at an angle 0
vpeak as the highet voltage at an angle 90
v1 as the voltage at an angle 180 i.e voltage at the end of the +ve half cycle.
And also let me know what happens during -ve half cycle?
welcome to pf!
hi skylines! welcome to pf! :smile:
the charge of a capacitor behaves the same as the voltage …
they go up and down exactly together (whether it's AC or not)
since current is the derivative of charge, current in sinusoidal AC is always 90° ahead of voltage :wink:
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
