Understanding Car Collisions: Mass, Velocity, and Acceleration Explained
  • Thread starter Thread starter jsr219
    Car Collisions
In a head-on collision between two cars, where one has mass m and the other has mass 2m, car 1 experiences a greater acceleration due to its smaller mass. Both cars traveling at the same velocity will experience equal impulse, similar to one car colliding with a wall. However, car 1 receives a larger impulse than car 2 because of its lower mass. The discussion emphasizes that during collisions, equal and opposite forces act on both vehicles, leading to different accelerations based on their masses. Understanding these principles is crucial for grasping the dynamics of car collisions.
jsr219
If car 1 has a a mass(m) and car 2 has a mass(2m), in a head on collision, with both cars traveling the same velocity, which car experiences a bigger acceleration ?
my answer - car 1
If two identical cars with identical speeds and masses collide, the impulse received by each car is the same as if one of the cars collided with a wall ?
my answer - yes
Car 1 has a mass(m) car 2 has a mass(2m). In a collision while moving with identical velocities, does car 1 receive a bigger impulse than car 2 ?
my answer - yes
I'm new to collisions, momentum, and impulse
If someone could throughly walk me through the problems I would really appreciate it.
If I'm wrong please point it out, I deff. can't learn from my mistakes without knowing I made any
Thank you !
During collision there are equal and opposite forces acting on the cars.
F = ma_1
F = 2ma_2
bigger mass, same magnitude force, less acceleration?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
