Calculating Velocity of a Car Rolling Off a Cliff
  • Thread starter Thread starter loganblacke
    Car
A car rolls down a 15.6-degree incline for 27.5 meters before falling off a 57-meter-high cliff. The acceleration due to gravity is calculated as -2.63 m/s², and the velocity of the car at the cliff's edge is determined to be 12.04 m/s. The initial vertical velocity when leaving the cliff is found to be 3.24 m/s. A quadratic equation is set up to solve for the time of fall, resulting in an incorrect time of 3.748 seconds. The discussion emphasizes the need for clarity on calculating the final velocity and its implications for solving the problem.
loganblacke
A car is parked on an incline of 15.6 degrees below the horizontal, the brakes fail and it rolls down the incline 27.5m and off the edge of a cliff that is 57m above the ground. Find the car's position when it its the ground relative to the base of the cliff.
rather than type them all out, I'll just say kinematics.
I know you have to break the gravity vector up into components so I took -9.8 sin(15.6) = -2.63 m/s^2. I keep calculating the average speed of the car, not the speed at the point it goes off the cliff. Please help, thanks!
v^2=u^2+2as, so the car is traveling at (2*9.8sin(15.6)*27.5)^0.5 when it goes off the cliff.
You have not said enough. You keep calculating the average speed. Do you want to calculate the average speed? Could you use the average speed? What is your plan for this question?
Thanks, but I'm still getting the wrong answer. I end up with the velocity of the car being 12.04 m/s when it leaves the cliff. So initial velocity in the y direction when the car leaves the cliff should be 12.04*sin(15.6) = 3.24. Plug that into y=Vi(t)-4.92(t)^2 to solve for t. End up with 57 = 3.24(t) - 4.92(t)^2.. rewritten in quadratic form.. 4.92t^2-3.24t-57=0. then t = 3.748 seconds which is not correct.
How is that not enough information? You have a car rolling down a slope then off a cliff. You obviously need to know the velocity of the car as it rolls of the cliff to answer the question. I calculated the acceleration but couldn't remember how to get Vfinal.
