Car speeding up around a circle
  • Thread starter Thread starter ooccoo
    Car Circle
The problem involves a car moving in a circular path with a specified radius, initial speed, and tangential acceleration. Participants are tasked with determining various kinematic quantities at specific times during the car's motion.
  • Mixed
  • Participants discuss the initial conditions of displacement, velocity, and acceleration, with some suggesting that displacement is zero at t=0. Questions arise regarding the radial component of acceleration and how it relates to the overall acceleration.
  • There is exploration of the implications of the given time and distance traveled, with suggestions to calculate the time to travel a quarter of the circle based on the initial speed and acceleration.
  • Some participants express confusion over the consistency of the problem data, particularly regarding the radius and its impact on calculations.
The discussion is ongoing, with participants sharing insights and questioning the assumptions made in the problem. There is no explicit consensus, but several productive lines of inquiry are being explored, particularly around the definitions of displacement and acceleration in the context of circular motion.
Participants note potential inconsistencies in the problem's data, specifically regarding the radius, which may affect the calculations. There is also ambiguity about the definition of displacement in this context, as well as the interpretation of acceleration components.
ooccoo
A car is being driven around in circles. The radius of the circle being made is R = 150.0 m. At t = 0, the car is on the left edge of the circle (therefore it is in the −x direction away from the center of
the circle if your origin is placed at the center), and it is moving in the +y direction. The initial speed is 12.0 m/s. However,
it is speeding up, with dv/dt = 1.00 m/s^2.
(a) What are the values of the displacement, velocity, and acceleration at t = 0?
(b) At time t = 10.83 s, it is now directly in the +y direction from the center of the
circle. What are the values of the displacement, velocity and acceleration?
(c) What was the average acceleration between t = 0 and t = 10.83 s?
(d) What is the value of t when you return to the position where you started?
a=(dv/dt)(v-hat) - (v^2/R)(r-hat)
the hats are a function of where you are, and always point in different directions
and I believe a-hat would = a(vector) / |a (vector)| <<Absolute value... like magnitude.
For a.) I believe that displacement would be 0 since the car hasn't moved. Velocity would be 12m/s in the +y direction, and acceleration would be 1.00 m/s^2 since acceleration is the derivative of velocity
For B, I start to get lost. I believe that I need to use the equation: [a=(dv/dt)(v-hat) - (v^2/R)(r-hat)]
I know that velocity is tangent to the circle and if the speed was constant, the acceleration would point directly at the center of the circle(making this problem easier) but instead it is point slightly forward
but I am getting thrown off by the fact that we're given the amount of time that has passed and the distance traveled (a fourth of the circumference)
any help would be greatly appreciated, my semester is almost over and I really want to understand this stuff before i go home for winter break. Thank you for your time!
I suspect they mean displacement measured from the origin.
Don't forget that it's moving in a circle. What about the radial component of acceleration?
You needed that for A as well.
OK.
It seems as if you are given too much information. Given the initial speed, radius, and tangential acceleration, you should be able to calculate the time to travel 1/4 of the circle. (Try it!)
Unfortunately the data do not seem consistent. Are you sure you are presenting the problem exactly as it was given?
In fact I am, which is why I'm confused. I'll try working with your reply and if i have an Aha! moment i will add on here. thank you!
Perhaps what they meant by acceleration is the centripetal acceleration? If the linear acceleration is given?
I would think not. Displacement should mean change in position.
No, I agree with Doc Al they likely mean total acceleration, so the vector sum of the two. But it would have been better if they'd written the tangential acceleration as d|v|/dt.
It would match up if the radius were 120 m.
That's what it should mean, but from what point? (I suppose you can take the point where t=0, but that wasn't specified.)
Good catch. I'll bet the 150 m is a typo.
  • · Replies 42 ·
  • · Replies 20 ·
