What Limits a Car's Acceleration at Zero Velocity?
  • Thread starter Thread starter fk378
    Car Rest
The discussion centers on the factors limiting a car's acceleration from a standstill, emphasizing that it is not solely the engine's power. The equation provided indicates that acceleration is influenced by power over velocity and air resistance, but at zero velocity, the acceleration theoretically approaches infinity. However, the coefficient of static friction is identified as a crucial factor that restricts acceleration in the initial moments. The drag coefficient of 1 is also noted, but it becomes less significant at zero velocity. Ultimately, static friction is the primary limiting force during the car's initial acceleration phase.
fk378
For a car starting at velocity=0 m/s, what would limit the acceleration in the first fraction of a second? (It's isn't the power of the engine) Use the fact that the force acceleration the car is the power over the velocity minus the air resistance force. The drag coefficient is 1.
a=(P/v)-(.5Av^2)
where A=cross sectional area
All I can see is that if v=0, then the first term for the acceleration approaches infinity. But in the question it says it doesn't have to do with the power.
a=(P/v)-(.5Av^2)
The coefficient of static friction acts upon the wheels of the car in the first fraction of a second--it'll limit the acceleration.
I forgot to add in the part that the drag coefficient=1
Is your answer still right?
What's your question? If it's asking what forces limit the maximum acceleration during the first second, then yes, I think I'm correct.
