Car with mass of 1500kg and thrust of 4000N
  • Thread starter Thread starter jtwitty
    Car Mass Thrust
The problem involves a car with a mass of 1500 kg and a thrust of 4000 N, while considering a constant air resistance of 500 N. The original poster seeks to determine the car's speed after 10 seconds, starting from rest.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss calculating net force by subtracting air resistance from thrust, leading to different acceleration values. There is also a focus on ensuring correct unit application and addressing potential errors in calculations.
The discussion includes various attempts to calculate acceleration and velocity, with some participants providing corrections and clarifications regarding the calculations. Multiple interpretations of the results are being explored, and there is no explicit consensus on the final answer.
Participants note discrepancies in the mass value used in calculations and the importance of significant figures in reporting results. The original poster expresses difficulty with the problem, indicating a need for further clarification.
jtwitty
Sorry; this is like soooooooo hard
A car with a mass of 1500 kg has en engine which can produce 4000N of thrust. Assume that the air resistance on the car is a constant 500N. If the car starts from rest, how fast will it be moving after 10 seconds.
d=1/2at2+vit
a=f/m
a = 4000 / 15000
a = .2666666666666666666666666666666666666666666666666666666666
thats about as far as i can get because that a has to be wrong?
heres what i just came up with
netforce = 4000 - 500 = 3500
a = 3500/1500
a = 2.4
d= 1/2a(100)
d=120m
a = vf /t
vf = 24
First you need to determine what the NET force will be on the car. In this case you have 4000N of thrust in the positive x direction (indicate as 'right' on your free body diagram), you also have a 500N resistive force due to air drag (left).
Your net force will be 4000N-500N (3500N).
Since [itex]F = ma[/itex], [itex]a = \frac{F}{m} = \frac{3500}{1500} = 2.33333[/itex]
Remember to look at the units of the values you are given. For some reason you added another 0 to your mass, which is why you got that strange value for a.
From that value of a you should be able to determine the velocity now after 10 seconds, use constant acceleration forumlae.
Edit - ninja'd.
Edit2 - One small correction to your answer. Since 3500/1500 = 2.33333333, rounding up to 2.4 is incorrect. 2.3 would be the appropriate value if significant figures aren't important for this problem. Thus your final answer would be 23m/s
haha :)))
thanks so much man :)
9K
