Cart down a ramp, acceleration of 0.6m/s^2
The discussion revolves around the unexpected low acceleration values (0.6m/s² and 0.2m/s²) obtained from rolling a cart down a ramp, compared to the expected 9.8m/s² for free fall. It is clarified that the acceleration along the ramp is influenced by the ramp's slope and friction, not just gravity. The acceleration value of 9.8m/s² applies only when an object is in free fall, while rolling down an incline results in lower acceleration values. The relationship between the angle of the ramp and gravitational force components is highlighted as a key factor in determining the cart's acceleration. Understanding these principles helps explain the observed results in the experiment.
jnimagine
We rolled down a cart down a ramp with a tickertape. When the average velocities were calulated and they were used to calculate acceleration. But we got acceleration of like 0.6, 0.2m/s^2 etc... shouldn't it be 9.8m/s^2..?! When i graphed the average velocity and the line of best fit was drawn and the slope calculated i got 6.5m/s^2. Why did i get an acceleration of such numbers like 0.6?? What are some explanations to account for this acceleration?
In which direction does the cart's weight act?
um.. the cart's weight acts down??
Down the ramp or directly down towards the centre of the earth?
down toward the earth... so there are two directions involved in this motion??
so 9.8m/s^2 is the acceleration down towards the earth... then what would be 0.6m/s^2??
cart down a ramp accelerates at 0.6m/s^2?? not 9.8m/s^2?
The acceleration depends on the slope of the ramp. 9.8 m/s^2 would only be expected if the ramp were vertical--the cart was in free fall. :wink:
This is easy enough to calculate by finding the component of the gravitational force that is applied along the slope of the ramp. It's simple trigonometry.
then what is 0.6m/s^2?
Re-read Doc Al's post.
Acceleration is equal to gravity only if the object is in free-fall. If the object is rolling or sliding down an inclined plane, the acceleration is dependent on friction and the angle of the incline. Remember that acceleration down an inclined plane is independent of the mass. Hope this helps!
