Cartesian product of open sets is a open set
The discussion revolves around the proposition that the Cartesian product of open sets in metric spaces is itself an open set. The original poster introduces the context of metric spaces X and Y, and considers subsets A and B that are open within these spaces. The inquiry focuses on whether this proposition is valid and worth proving.
  • Participants explore the relationship between open sets and open balls, with one suggesting that the problem can be simplified to considering open balls in the respective metric spaces. There is a discussion about how to demonstrate that the product of open balls is open in the product space.
Some participants have offered insights into the definitions of open sets and the properties of Cartesian products. There is an ongoing exploration of the implications of these definitions, particularly in relation to arbitrary metrics on the product space. The discussion reflects a mix of reasoning and attempts to clarify the validity of the original proposition.
Participants are navigating through definitions and properties of open sets and metrics, questioning the assumptions underlying the proposition. There is a noted complexity in demonstrating the openness of the product of open sets, particularly when considering different metrics.
ELESSAR TELKONT
This is not really coursework. Instead, this is some sort of curiosity and proposition formulation rush. Then the initial questions are that if this is a valid result that is worth to be proven.
Let X,Y be metric spaces and X\times Y with another metric the product metric space. A\subseteq X, B\subseteq Y be open sets, then A\times B\subseteq X\times Y is open.
Definition of open and metric properties.
The problem is possible to be reduced to the case where A,B are open balls in X,Y respectively, since one definition of openess is based on the fact that a every point in an open set has some neighborhood contained into the set. Then I think there must be a relationship between metrics on factor spaces and product space one. There is where I'm stuck.
Any point in A x B can be written (x, y) with x in A and y in B. What can you say about balls centered on x in A and on y in B?
Well, as I have said in my first post this can be reduced to think about balls. I'll go more explicit about this.
As Halls of Ivy said if z\in A\times B, by definition of cartesian product there are some x\in A,\, y\in B such that z=(x,y). Since the factor sets are open in their metric spaces X,\,Y there are some \epsilon_{1}>0,\,\epsilon_{2}>0 such that B_{x,\epsilon_{1}}^{\rho_{1}}\subseteq A,\, B_{y,\epsilon_{2}}^{\rho_{2}}\subseteq B, this is by definition of open set. But then is obvious, from results of cartesian product that B_{x,\epsilon_{1}}^{\rho_{1}}\times B_{y,\epsilon_{2}}^{\rho_{2}}\subseteq A\times B\subseteq X\times Y.
Then, if I prove that B_{x,\epsilon_{1}}^{\rho_{1}}\times B_{y,\epsilon_{2}}^{\rho_{2}} is open and since for every z\in A\times B can construct this then there is some ball B_{z,\epsilon_{3}}^{\rho_{3}}\subseteq B_{x,\epsilon_{1}}^{\rho_{1}}\times B_{y,\epsilon_{2}}^{\rho_{2}}\subseteq A\times B and the cartesian product is open in the product space.
How do I show this with an arbitrary metric \rho_{3} on the product space?
I tried with contradiction argument on this:
Let B_{x,\epsilon_{1}}^{\rho_{1}}\times B_{y,\epsilon_{2}}^{\rho_{2}} no open in (X\times Y,\rho_{3}). Then there is some z_{0}\in B_{x,\epsilon_{1}}^{\rho_{1}}\times B_{y,\epsilon_{2}}^{\rho_{2}}=C such that for every \delta>0 B_{z_{0},\delta}^{\rho_{3}}\cap C\neq\emptyset\land B_{z_{0},\delta}^{\rho_{3}}\cap((X\times Y)\setminus C)\neq\emptyset.
But that implies the following: For every \delta>0 there are some z_{\delta}\in B_{z_{0},\delta}^{\rho_{4}} such that exists \xi_{\delta}\in X,\, \eta_{\delta}\in Y but \xi_{\delta}\notin B_{x,\epsilon_{1}}^{\rho_{1}}\lor \eta_{\delta}\notin B_{y,\epsilon_{2}}^{\rho_{2}}. Then \rho_{1}(\xi_{\delta},x)\geq\epsilon_{1}\lor \rho_{2}(\eta_{\delta},y)\geq\epsilon_{2} but \rho_{3}(z_{\delta},z)<\delta.
Although I reach this I think the conclusion is not right. The conclusion is: Since this is for every \delta>0 then I have a set of points that approximates to z for decreasing \delta>0 but in the balls on X,Y they go farther or stay at the same distance. This is not possible, then the suposition that the product of balls is not open in (X\times Y,\rho_{3}) leads a contradiction then the product of balls is open in (X\times Y,\rho_{3}) and then the product of any open sets is open in (X\times Y,\rho_{3})
Is it right?
