Cast Iron pitting with high heat
  • Thread starter Thread starter johnl
    Heat Iron
Craters forming on heated cast iron surfaces, such as exhaust headers, is linked to high temperatures and corrosion processes. When exhaust leaks occur, they trap heat between the cylinder head and the exhaust header, leading to elevated temperatures. This increase in temperature accelerates diffusion rates, which in turn speeds up corrosion. The phenomenon observed is a result of these thermal and chemical interactions, highlighting the impact of heat on the integrity of cast iron components.
johnl
I have noticed on cast iron surfaces that have been heated pretty well, they form craters on the surface. I have seen it on exhaust headers on cars where the timimg was wrong. I was wondering if this is a standard phenomenon and what action is occurring here to cause this?
thanks
John
I think what's accelerating the corrosion to the exhaust header is the high temperatures. If you have a leak in the exhaust, you will end up trapping heat between the cylinder head and the exhaust header. This increased temperature raises diffusion rates and hence speeds up the rate of corrosion.
