What is the optimum pitch angle for ceiling fan blade design?
  • Thread starter Thread starter Pang Chun Wai
    Design Fan
The discussion centers on designing an efficient ceiling fan blade with an airfoil section, tapering, and twisting. There is skepticism about the effectiveness of airfoil designs compared to flat blades, as traditional ceiling fans typically use broad paddles that do not spin fast enough for narrow blades to be beneficial. However, one participant acknowledges that airfoil sections can be practical, especially when starting with a wider chord that tapers down. The conversation highlights the need for further insights and responses from others in the forum. Overall, the quest for the optimum pitch angle remains a key focus in achieving high efficiency in ceiling fan blade design.
Pang Chun Wai
For the final year project that i am doing, I need to design a high efficiency ceiling fan blade with airfoil section, tapered and also twisting. Can anyone tell me how can i obtain the optimum pitch angle for different section of my ceiling fan blade?
I doubt that an "airfoil section" will make much difference over a flat angled blade in a ceiling fan situation. Most use very broad "paddles" as opposed to "propellors" such as an aeroplane would have. They just don't spin fast enough to use a narrow blade. It's hard to impart an airfoil shape to a fat one. I might be missing something here, though, so wait for a response from someone else.
no one is replying me...zzzzzz.. tis article have show that the airfoil section for ceiling fan blade is practical
I stand corrected, and am actually quite impressed by those figures. In my defence, I didn't realize that the blades started with a 6.5" chord and then tapered down. I was envisioning about half of that.
Hang in there; somebody is eventually going to show up.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
