What Are Cells in a Laptop Battery?
  • Thread starter Thread starter swraman
    Battery Cells
A laptop battery consists of multiple cells, which can be connected in series or parallel to achieve the desired voltage and capacity. A fully charged lithium battery cell typically has a voltage of about 4.2 volts, and the configuration of cells affects battery life and performance. Generally, a battery with more cells, like a 12-cell battery compared to a 9-cell, can provide longer usage time, assuming they have the same charge capacity, such as 7200mAh. However, the actual performance can vary based on the specific cells used in different laptops. Ultimately, choosing between a 9-cell and a 12-cell battery may depend on the balance of internal resistance and the quality of the cells.
swraman
Hi,
Im looking for a new laptop battery.
Something that's confusing me is the number of cells in a battery; what is a cell? is it a smaller battery that exists in the larger battery?
If so, are the cells connected in series whose voltage sums to the voltage of the total battery?
Or are the "cells" connected in parallel...for reasons I can only guess at?
Also, and more to the point I am trying to figure out: I know laptop batteries are rated in mAh, how much charge it can hold. But would it be better to get a 12 cell battery or a 9 cell battery, both with the same charge capacity?
My intuition would be that fewer cells would be better because the lifetime of the battery will be longer: Since the internal resistance of the battery builds up in each cell, there will be less internal resistance if there are fewer cells (since they are in series).
Here I am assuming that all the cells, whether they are in a 9 or 12 cell battery, develop internal resistance at the same rate; which I don't know if is true.
Thanks for any help
Raman
A fully charged lithium bettery cell has a voltage of about 4.2 volts. The bigger the area of the cell, the more amps it can provide. Put 3 cells in series and you have a 12-volt battery. Put 3 cells in parallel, and you have a 4 volt battery that can deliver the same current 3 times longer.
In other words - if you have a choice of batteries for the same laptop the battery life will be proportional to the number of cells. A 12cell will last 1/3 longer than a 9 cell
This isn't necessarily true between different laptops - the cells might be different.
Will this be the case even if the 12cell and the 9cell have the same charge capacity? The 2 I am looking at both can hold 7200mAh, but one is 9cell and one is 12cell.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
