Center of Gravity: Rod Kicked Quickly - What Happens?
Kicking the bottom of a vertically balanced rod generates torque around its center of gravity, causing it to rotate while also falling due to gravity. The center of gravity moves downward and to the side, resulting in a "southeast" trajectory as it experiences both gravitational and horizontal forces from the kick. The initial impulse from the kick gives the center of mass a non-zero initial velocity, leading to a parabolic path until the rod contacts the ground. Understanding the dynamics involves considering all forces acting on the rod. The discussion emphasizes the interplay between torque and gravitational forces in determining the motion of the rod's center of gravity.
bsmith2000
My friend's little brother took some physics test a week or so ago, and he was asking about some of the questions that were on it. This was one of them:
There is a rod (uniform density, mass) which is balancing on the ground on its end (It basically looks like a flag pole). Someone comes along and kicks the bottom of it really quickly - describe what happens to the center of gravity (also the geometric center) of the rod.
F_g = m_c*g
\tau = F \times d
I figured that kicking the bottom of the rod would cause a torque around the center of gravity, so the rod would rotate. However, you also have gravity acting on the center of gravity, so the rod would fall downwards. Therefore, the center of gravity just moves straight down until it hits the floor.
Any thoughts/critiques/suggestions?
To find out how the center of mass would accelerate, consider all the forces acting on the rod.
I think I know what you mean. If this was the set-up,
O ||
and the man kicked it, then the force from the kick going to the right plus the downward force of gravity would cause the center of mass to move in a "southeast" direction, correct?
Does anyone have any suggestions? I am curious to know the answer.
The rod would have an initial impulse from the kick that would give the center of mass a non-zero initial velocity in addition to the angular momentum. The center of mass would follow the same parabola as a point mass with the same initial velocity (until some part of the rod hit the ground).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
