Center of Mass Identical Size Object Connected by Spring
The discussion revolves around the calculation of the center of mass for a system of two identical blocks connected by a spring, subjected to an external force. The initial and final positions of the blocks are provided, with specific coordinates given for the center of mass. A user attempts to calculate the center of mass using the formula but receives feedback that their method is incorrect. The conversation highlights the need to consider the spring's properties and the relationship between the blocks' accelerations when determining the final center of mass. The problem emphasizes understanding the dynamics of the system, particularly the effects of the applied force and spring constant.
Crazynutjob
Two identical 0.19 kg blocks (labeled 1 and 2) are initially at rest on a nearly frictionless surface, connected by an unstretched spring, as shown in the upper diagram, where x2 = 0.05 m. Then a constant force of 8 N to the right is applied to block 2, and at a later time the blocks are in the new positions shown in the lower diagram, where x1 = 0.01 m and x3 = 0.12 m. At this final time, the system is moving to the right and also vibrating, and the spring is stretched.
http://www.webassign.net/mi3/09-056-two_blocks_and_spring.jpg
What is the final location of the center of mass of the real system?
xCM,final =
POINT PARTICLE SYSTEM
What is the initial location of the point particle system?
I tried (x3 -x1)/2 = (.12- .01)/2 = 0.055 m
this is incorrect according to web assign
what am i doing wrong.
Perhaps you could explain your reasoning. I am not sure that the problem is fully explained. Is the "final" position supposed to represent the maximum stretch of the spring?
What is the force on block 1 (hint: you have to assume a spring constant k)? How does the acceleration of block 1 affect the acceleration of Block 2?
AM
xcm = (m1x1 + m2x2)/(m1+m2)
